0 Members and 109 Guests are viewing this topic.
hyiq
Quote from: Zephir on February 02, 2017, 06:41:09 AM
The usage of shunts from thin glowing wire is disputable, because the metals change (decrease) their conductivity with increasing temperature a lot.
Therefore the R1 and R2 resistances may not be constant anymore.
Of course this is true, resistance does change with Temperature. Thermal Drift is a problem, commonly in Shunt Resistors and Heat Sinks can be employed to stabilise this Thermal Drift.
However, the Current was measured: (Analog Amp Meter and on the Scope)
Input: 2.8 Amps
Branch One: 5.1 Amps
Branch Two: 2.3 Amps
I have also done these experiments and the Currents do add, More Current is Circulating in L1 and L2 than from the Power Supply.
Thermal Drift does affect the result, but not enough to dismiss these effects for the Importance they hold.
After all, to anyone with an ounce of Common Sense, the image says it all: The fact is, both Elements should Thermally be the same if the RT Resistance is the same, and each should obey Kirchhoff's Current Rule!!!
Kirchhoff's current law (KCL) This law is also called Kirchhoff's first law , Kirchhoff's point rule, or Kirchhoff's junction rule (or nodal rule). ... At any node (junction) in an electrical circuit, the sum of currents flowing into that node is equal to the sum of currents flowing out of that node.
Very Clearly, this is not the case!!! Simply because we have an Active Element in L3, where Electromagnetic Induction occurs, and thus it becomes a Source of Electrical Energy! L3 has become a Battery if you like! Which is the ONLY exception to Kirchhoff's Current Rule!
   Chris Sykes
       hyiq.org
hyiq
Quote from: citfta on February 02, 2017, 02:44:33 PM
Hi Chris,
I have been following this thread for over a year now.  I have seen page after page where you have presented your theory of partnered output coils.  In all that time I have not seen any real demonstration to verify your claims.  Did I miss that demonstration?  I am not asking about more pages of your theory.  I want to see an actual device with input and output power shown that will back up your claims.  You have had plenty of time to put something together to demonstrate your claims.  Can you do that?  That would answer a lot of questions.  If you can't do that then why are you here?  Your claim of hard facts means nothing if you can't back that up with hard evidence.
Respectfully,
Carroll
Hi Carroll - I am going to be a little blunt, so forgive me: I am not showing any more experiments.
I have shared many years of experiments on my YouTube Channel, most all of my videos have minimal views, no one is interested, no one understands, no one replicates. After several years, 3K Views on some of my most important videos, is a very pitifull effort. People will ONLY learn, if they get on the Bench and replicate!!! It is more productive for me to spend time here, trying to get this Tech Out to those that have an Open Mind!
What are my claims anyway, this debate I have been down the path with all the OU.com Goons for years now. I did state:
Quote from: EMJunkie on January 21, 2015, 04:01:23 AM
I am not going down the "Measurement" path - Bill Alek a qualified EE has been ridiculed without any evidence to the contrary. My measurements are not up for debate here.
I am giving people the How's, Why's and the Secrets to build their own Devices. Its up to them to make their own decisions.
I encourage people to use their Common Sense and decide for themselves if this device makes sense and is worth the 1hr and $20:00 to Build and Learn.
Carroll, you see, Human nature is such, that if a result is not seen immediately, then its seen as a "Give Up" situation and it "Doesn't Work" - I have built many thousands of devices over the years, many I was not able to make work, but it most certainly does not mean that the Ideas and Concepts behind the Device are fake or a fraud, it just means that I failed in my attempt!
Its true, when one really truly understands something, all else will follow.
I am not going to be one of those fly by nighters, I will try to share what I have learned, for those that are interested, and then their progress will speak for itself. As it already has.
So, lets be straight up, My Claim is: "If you wish to learn something of value, then what I am sharing holds great value, if not, then No Worries"
Many Many people are seeing results, That's why I am here, for no other reason!!!
Quote from: darediamond on January 15, 2017, 03:08:25 AM
Chris is right. Bucking coil when properly connected have no lenz at all and still gives output.
You can all see that my set-up is fucking Crude or rough. But still I get the effect. I loaded the secondaries and still there is no increment at all in the input wattage.
The whole P.O.Cs is covered by the primary.
You need to separate the charge by applying Vladimir Utkin Circuit which he stated in his PDF document under the title "Switchable Iinductance"
I am now moving away from that circuit to test full bridge and earthing circuit to see if I will able to draw current from the Earth Crust with or without Avramenko Plug.
Frequency to the primary from my mechanical switch was under 30hz
Input voltage to my primary was 90 volt DC.
The output wattage I crease as I increase the frequency. But MY LOAD WHICH IS A DC MOTOR DID NOT AFFECT THE INPUT WATTAGE AT ALL. I REAPEAT AT ALL.
Now time to test Bucking  primary and one secondary as come.
I will also test single strand primary coil over the bucking secondary to see if the output watt will drop or not as I notice using neodymium magnet that current flowing in Multifillar wire mimicks AC zig zag or push pull even if the current is DC.
Thank you Chris, Vladimir Utkin, Marathonman, Hanon, Though and all you other people on over unity.com for your selflessness and sincerity
Quote from: Mark Balanger Advanced Electronic
https://www.youtube.com/watch?v=CPgnKpScGDA
Published on Dec 4, 2015
This difficult to tune circuit really does work. Once folks try to utilize my method of building and tuning, it will make life a lot easier to get one functioning. A magnet is used to change the flux path of the device once it is powered up, and, it seems that once used in a few different areas, the longer it remains powered and the frequency is found per size of the load, a device will need to be used for eacdh large device we utilize without the danger of being charged for that amount. Since this device uses from the uA to the mA range of idle current it is vital to know it can be used for very large loads such as continuous water or fuel pumps, and, many other devices.  Why aren't we building them for power in our homes ?? The coils use minimal idle amperage like wall wort power supplies, but at a much lower amperage. When we add load, the amperage dropped.  The more we add. The lower it goes. This cost me $2.25 worth of ferrite and copper to make.
Quote from: Wistiti
www.youtube.com/watch?v=RKfr8bwVhkc
Published on Feb 25, 2015
There is my second video on youtube!
In this one i tried the partnered bucking coil presented by Chris Sykes "EMJunky" on an already made toroidal transformer...
The only thing i would like to add is Thank you Chris!!!
https://www.youtube.com/watch?v=jWzZqw8eLDU
Published on Sep 4, 2015
A little-known "Aharonov-Bohm effect" (1959) is working against the old and known "Lenz's-Law" (1833). The result is an "anti-Lenz" effect.
Soon will be a video: "Anti-Lenz effect - the final version".
Quote from: Thaelin on December 09, 2015, 02:16:31 AM
Yuri did what I did, and got the same results. It baffels you to see it.
Even worse, is when you try to prove yourself wrong and the results
hold rigid.
Now lets see how bad the pack tears this one up.
There are many many more also!!!!!!! Now what should be SUPER EVIDENT, is that this has never happened before in the history of Energy Machines, many many independent replications, many hundreds now, all of varying levels of achievement!!!
   Chris Sykes
       hyiq.org
P.S: My YouTube Channel has a Total of: 58 Videos, some are private, for very good reasons. Nearly all my videos contain information about my Experiments!
hyiq
Rest assured, in Time, I will share more, when others catch up. Not until then. There is no point confusing people with more than they can handle.
The enemy of every Human Being, is the Arrogant Mind, where the Arrogant Mind "Thinks it already knows all" and "There is no more to learn"
It is true, we have missed some of the most simple parts of Science!!! Entirely!!!
Today I was fortunate enough to see something that was "Out of this World" - Amazing. So, I have hope, hope that the Liars and Cheats in this world will fall flat on their faces, very soon. What I saw was enough to bring me, this hope, to see that there is very much more than our crooked civilisation, filled with terribly behaved Cry Babies and Fools of Greed!
This play yard is about to get the biggest upgrade that has ever happened, if you're not ready, then you will be swept out with the Rubbish!!!
   Chris Sykes
       hyiq.org
barbosi
Quote from: hyiq on February 03, 2017, 02:55:22 AM
hyiq.org
That in conjunction with your own poll:
EMJunkie has provided us with a wealth of Information? (2 Votes)
To me it looks that you've got a new bicycle and still can't get a date.
See the fulcrum now?
When the Power of Love overcomes the Love of Power, there will be peace.
hyiq
Quote from: barbosi on February 03, 2017, 10:11:58 AM
BarBosi - What exactly are your life achievements?
Have you done anything, ever, to help someone else out? Ever?
What goals do you have, do you know what a goal is?
You see, I see so many complain, like cry babies, but I see not a single ounce of effort on the part of these cry babies to achieve anything, ever!
You all fall into the same basket, "Spoilt little children that stomp your feet if you don't get what you want"
I would rather be more constructive, see there are Do'ers and there are Do'Noters, I am a Doer, you're a Do'Noter, I have done the experiments and Learnt something of value, you on the other hand, keep coming here, complaining, achieve nothing and Learn Nothing!!!
For Readers that have read and understand very simple English Language, there was a post that bought that Poll about, if you care to find it and read it, but I know you wont, Too Hard isn't it BarBozo!!!
We shall see if you fair as well?
Edit: WOW 3 Down Votes instantly? WOW not looking so good!
   Chris Sykes
       hyiq.org
