0 Members and 38 Guests are viewing this topic.
hyiq
Quote from: bitbo on February 16, 2017, 07:08:49 AM
This setup will allow me to try several combinations:
a) Primary coil on the left (bifilar or parallel wired), bucking secondaries in the middle
b) Primary coil on the right (single wire, not yet wound), bucking secondaries in the middle[/size]
c) Primary coil on the left AND right (bifilar or parallel wired), bucking secondaries in the middle[/size]
d) Primary coil on the left (bifilar or parallel wired), bucking secondaries in the middle, tertiary on the right (bifilar or parallel or single)[/size]
[/size]
I do not have much time for this these days, but we will see what i get from it
I´ll keep you informed here....
bitbo
Nice Work BitBo!!!
Yes, Sorry:
   AuroraTek Demonstrates Overunity Transformer at TeslaTech 2014
   AuroraTek demonstion tesla tech 2014 overunity? (Russ's View)
   AuroraTek Energy Device
I wasn't impressed with Bill's Lecture Video. He does a lot better in the above videos.
I have said before, this Tech Has been around for a long time, its not new, its just that no one has spent any time bringing it forward and explaining how it works! I would recommend studying the Greats, Floyd Sweet, Don Smith, Lester Hendershot, and many others that have used the exact same Tech...
   Don Smith - How to Generate Energy - Use the Right Hand Grip Rule to see what Don is Saying!!!
   Notice the Turns Ratio: 4:17 = 1:4 approx. Floyd Sweet was 1:5, Paul Raymond Jensen was 1:3
   Chris Sykes
       hyiq.org
Dog-One
Quote from: hyiq on February 16, 2017, 03:18:25 PM
Stan Meyer 1:6 of 29 AWG wire.  Primary ~500 turns, POCs ~3000.
And yes Chris, I have joined the club working full-time on an exact Meyer's VIC replication.
There is one fellow that has seen success and there will be others as we zero-in on the
critical aspects, one of which being DC impedance.  The coil winding resistance and
turns ratio factor must be exactly matched.  When you do the calculations you will
discover that only certain wire sizes can be used.  Distributed resistance throughout
the length of coil wire is something most overlook, but it is indeed important.
You are dealing with waves of energy in motion in these devices.  Never forget this
fact.  Those waves bounce/reflect in ways your oscilloscope cannot detect.  You must
comprehend this and work accordingly.
Please PM me sometime and we can talk more about it.
hyiq
Quote from: Dog-One on February 16, 2017, 04:10:08 PM
Hey Dog-One - Nice! Stan Meyer is, and will forever be, a Legend!
I still have a lot to learn, I don't fully understand the significance of why this ratio is important, but:
Quote from: Floyd Sweet
We are all familiar with AM and FM propagation, where in the case as AM, the voltage amplitude varies, and with FM, the frequency is modulated.
However, the output power sees a constant load impedance, that of the matched antenna system. If this changes, the input to the antenna is mismatched, and standing waves are generated resulting in a loss of power. The frequency is a forced response and remains constant. Power is lost and efficiency becomes less and less, depending on the degree of mismatch.
Now, without an Earth, the 1/4 Wave Length is not Significant. One needs to go to the 1/2 Wavelength if one does not have an Earth. So I am not sure here why we go to the approximate 1/4 Wavelength as we have no Ground...
I am sorry, I wish I had more answers in this area.
   Chris Sykes
       hyiq.org
itsu
I set up the similar configuration as MrPreva and got similar results.
No way however to get 5.1 or 2.8 etc. Amps when using a FG at 73Khz and 15Vpp.
I toke a 1uF capacitor as i did not know the value being used.
The both currents across 1 Ohm resistors are almost 180° out of fase (150° really) and we have the lesser current in the lower turns (43mA with 7 turns versus
26mA with 11 turns)
Input into the circuit is about 13mA which is close to the difference between the two branches of the toroid.
Not sure what the significance of this setup is as the 13mA input is the real input into the circuit and the 43ma and 26ma are reactive as i understand it.
Video here: https://www.youtube.com/watch?v=GHA6hnKziAU&feature=youtu.be
Regards Itsu
hyiq
Quote from: itsu on February 16, 2017, 05:19:57 PM
26mA with 11 turns)
Video here: https://www.youtube.com/watch?v=GHA6hnKziAU&feature=youtu.be   (still uploading).
Regards Itsu
Hey Itsu - Awesome!!! Thank you!!!
This is such a simple experiment but yet so much can be learned here!!! It is so very Un-Intuitive until it is understood, then it is so very Intuitive!
With some fiddling, it is possible to get a lot more phase shift. I honestly believe, this is perhaps one of the most important experiments one can do to learn.
If you compare the Voltages, they are in Phase, but the Currents are Out of Phase as you say. Now, intuitively, the ±180 Degrees Current to Current Phase Shift is Electromagnetic Induction, however, the odd thing one would not normally see, is the ±180 Degree Voltage to Current on L3. Typically, we would see ±90 Degrees from Voltage to Current, or Current to Voltage.
Great Job Itsu!!! This I am very pleased to see. The tiniest things will very often yield the greatest significance!!! The actual significance here, is that each Magnetic Field in these two Coils Oppose as do the Currents Oppose!
Again, back to the significance, once the right parameters are met, the Primary has a net force +1 the SecondaryOne has a Net Force -1 and the SecondaryTwo has a Net Force +1
So Mathematically, we have: 1 + -1 + 1 = 1   -   Normally we would see: 1 + -1 = 0 meaning one Force Cancels the Other Force, or no Force left over.
Newtons Laws of Motion with out Addition: Action, Reaction and Counter-Reaction Which yields Output > One = Over Unity - Our Input can do Work, without Lenz's Law Reflectance, no Magnetic Opposition on the Primary!
   Chris Sykes
       hyiq.org
