0 Members and 120 Guests are viewing this topic.
tinman
Quote from: Mr.Miyagi on December 28, 2018, 07:17:01 AM
I get you have a job to do, a bad guy, working for the cabal, you have to mislead people as part of your job definition.
But, the truth is, it is documented.
This video series has at least one person do the required measurements: https://youtu.be/zfVomjwqHx8?t=433
Qualifications of the gentleman I do not know, but his math is solid.
Your effort to mislead people is so visible its almost sickening what you're doing!
You have to be kidding me  ::)
Let's annalise your !!!SOLID MATH !!! done in the video  ::)
This is one of your top EE guys you were talking about?--that carried out the power measurements of the Don Smith device ?
This is some sort of joke--right  :o ?/?
First sniff of bullshit--
Grid voltage in the U.S is 120 VAC
They claim 1000 watts of light bulbs are being lit.
That's 10 x 100 watt light bulbs,which consume 100 watts at a voltage of 120 VAC.
Now,they do have 10 x 100 watt light bulbs--but at what voltage are they being driven at ?.
At 5:10 in the video,your !switched on--top of the wozza-EE guy! measures the voltage across the bulbs,and guess what?-->he gets 64-65 VAC  :D\ . @ 6:45,he says the voltage is dropping-->this is your EE guy,who's math is solid  ;D
So,now the actual load has dropped from the claimed 1000 watt's,to near half-->500 watts.
Oh,and his device just so happens to put out a steady 60Hz frequency  ::) --much like an inverter lol.
@ 7:20,he then go's on to claim that driving this load with a 12 volt battery would mean the battery would have to deliver about 83 amps of current  ::)
500 watts / 12v =41.66 amps  :o
Then your EE guy (the one that carried out the sound math),described the battery as being about 6 inches long x 4 inches high x 3 inches thick. He then states that a battery this size could not deliver the required power to run that load for the 3 minutes they ran it (yep,a big 3 minute run for an OU device--while the battery voltage was dropping  ;D)
Now,that size battery he described is about the very size of an 8amp hour AGM battery.
These AGM batteries will deliver 50 amps,just not recommended--but they will do it.
But can it deliver 500 watts for 3 minutes ?
Well lets change that to hours.
so 500 watts / by 20 (as 20 x 3 minutes= an hour),gives us 25 watts for an hour.
So 25 watts divided by 12 volts(even though a good battery will be at 13 volts)=2.08 amps
So the battery has to have an amp hour capacity of 2.08 amp hours to deliver 500 watts for 3 minutes--and we have an 8 amp hour battery  ;D
Double check
500 watts /12v=41.66 amps
41.66 amps divided by 20 =2.08 amp hours  ;)
A 3 amp hour AGM battery is smaller than a 300ml can of coke lol.
Now,lets look at what you said-->your claim
Quote: Don had many demonstrations that could not be faulted at the time by electrical engineers.
And you give us this video as proof  :D
And then this
Quote: What definitive proof do you have to refute the work of years of tests done by electrical engineers that could not fault Don Smiths machines?
LMAO-->the video you just gave us lol.
You really are Chris's friend  :D
That video shows how you and Chris achieve OU  ;D ;D ;D
Your top EE guys measure things just as your top EE guy carried out his sound math in the video LMAO
Well,there go's any credibility you never had lol.
Brad
Mr.Miyagi
VERY clearly you paid attention to what you wanted to hear and missed the rest.
Clearly you know nothing of RMS and Mean voltage readings on the DMM's.
You are a complete fool, you know nothing of Inverters and Batteries!
When can an inverter's output voltage ever go up when being powered by a single battery?
You are a complete idiot that has no attention to detail.
Mr.Miyagi
Bradley Richard Atherton, you don't know the difference between RMS and Mean Voltage measurements!
You complete idiot!
Now everyone reading knows your true ability. The 707 you missed shows you know nothing of Electrical Engineering!
An idiot replacement!
You are a time waster, had a lucky fluke, the RT V3 that worked, and now you have nothing, the whole world knows why, because you have no attention to detail.
A man that had it all and now has lost it all, how fitting for you.
Mr.Miyagi
No reply?
Your mistakes this week are getting bigger by the minute!
When you miss 707 what are you missing Brad?
When you assume a 10 Ohm wire wound resistor to be 10 Ohms at > 2 Mhz and Claim 331% OU in front of the world - Its a pretty big mistake Brad!
You know, the Lies, the false claims of OU on a Capacitor - Your reputation is in tatters!
Quote from: tinman on December 25, 2018, 10:53:27 PM
Our COP in this test seems to be 331%  ???
Brad
