kolbacict
QuoteWith such few turns all you had was a lumped circuit probably vs your slow switching.
Do you want to say that there are few turns? But what about xenon lamp ignition devices, for example, on film projectors?There, such capacitors are discharged into several turns of a thick wire, and on the xenon lamp an ignition pulse of tens of kilovolts is obtained.Part of the circuit circled by me.
Toolofcortex
Lumped means very short line compared to risetime of signal= no reflection=no double direction.
reflection happens at wavelenght/2 , wavelenght... half integers.
Power mosfets that can carry 15 AMP+ are usually slower to switch than low power CMOS.
So for my design, its all balancing act. Somewhere around 10 MHZ seems manageable.
kolbacict
What do these devices (pictures) have in common?
Toolofcortex
Maybe the aboveunity group thinkers know?
I think however that they are useless copycat monkeys who can only say "yes man" and copy.
See anti.semitic as an example.
Typical low IQ follower.
Anti.Semitic
I wonder if it can be worked out. what is h3 and why is the answer h3? do we know? can we work it out, or is it too hard?
good luck, I hope you are able to work through one of the most simple equations I have ever seen!
perhaps insight to other devices, such as Kapanadze may be gleamed if you can muster the strength?
