Toolofcortex
The game is over Seychelles, I'm sorry.
You were beat by worthy opponent.
Cracked.
Donezoid.
Raycathode
Quote from: Toolofcortex on February 16, 2020, 10:31:28 AM
But the best way to use a magnet, is to make good use of every single line of force, so that it ejects weakly attached electrons.
As much of it as you can before the density is too much and wire breaks.
Those energy waves are your bullets, you pay only for the triggering, might as well shoot as many bullets as you can from your trigger input.
https://www.overunityresearch.com/index.php?topic=3888.msg79976;topicseen#msg79976
When all remains stiff an immobile? What happens? What gives up?
As I said before, dont put your body there, you will get your cells and DNA ripped to shreds.
BOOM! Pulse causes cancer instantly.
Mu metal played with that stuff when I was a kid !  get a scope tube and put a magnet on the side of it and watch the display, unless it's heat-treated to your setup of its useless iron sheet will work just as well unless you have loads of money to wast!
If you don't want cancer cut out wheat and pasta and soda pop products.
Toolofcortex
You cant mess with electron density razor blades.
I dont think Its safe.
This is for university only.
You would need to have that toroid right there and maybe have it started too in its momentum.
Raycathode
Quote from: Toolofcortex on February 16, 2020, 05:38:46 PM
Talking of toroids and Fritzie Chris the yoke used in Akula Dally device it might be easy to convert that to a bucking device I wonder if that would work ir the two halvers were wired to be opposing each other just an idea.
Confused about your razer blades thing stuck to your toroid what does that do ?
I have here a toroid test rig three matching oils but one reverse wound and wired to buck it lights a 10Watte lamp dimly 1/2 brightness but 12v at 10w is 1-2 amp the thing draws about 1.6 amp so where is the rest of the power disappearing too?
