0 Members and 69 Guests are viewing this topic.
EMJunkie
Quote from: AlienGrey on February 28, 2020, 06:34:22 PM
Point taken, although i'm not sure what you actuly objecting too here as it is a public thread.
The heading is Bucking coils, my posts were to point in the right direction.
If your the 'moderator' perhaps you should set up rules so we all know where we stand
At the same time the Moderator can certanly erase any of my postings forth with.
Kind regards AG
AG, you need not worry, I did not direct my comments toward you.
Best wishes,
   Chris
EMJunkie
In your Hand, grasp Electromagnetic Induction. Clasp your hand tight.
Close your eyes, let your imagination run wild, while focusing on extending the fundamental requirements of Electromagnetic induction.
Become auto-heuristic, for Electromagnetic Induction as we know it is not complete, not as well understood as we may think! We can do so much better if we only try! Shaft Torque is an Artifact, a side effect of Kinetic Energy. Kinetic Energy is simply the Flow of Current, Force, f = ma. Zero Charge is transferred from the Shaft to the Coils, there exists, Zero Electrical Connection! Shaft Torque is equivalent to M.M.F.
A M.M.F to M.M.F balance can be obtained with no Shaft, how do we achieve this?
Best wishes,
   Chris
To search machine : bucking coils and patent
Output : Schlumberger oil field search technology
              and hum voltage neutralizer in loudspeaker
A. working with thermal noise conversion/amplifying/diminuation = dB area
Instead bucking coils " bucking foils" and you will find in thermionic converter dB- amplifier wich gives input/output ratio gains :
For nearer future :
Joseph Yater US4004210 Reversible thermoelectric array with power conversion of energy fluctuations
Impressive : the potential power output PER CUBIC CENTIMETER of modules is 10v9 W
                      megawatts output per kilogramm
This technology as " two-stage-amplifier" used more  here : US5356484
Is heating a cw or ccw  medium moving ?
Is cooling a ccw or cw medium moving ?
When centrifugal or centipetal  ? Higher/lower density  !
To #8528 : the below MrPreva circuit : in the scheme ac as generator to circuit input :
                    Will we we do not get "only" half period output  ?
                   Two circuits for full swing/period !  1 period =  360° = Hertz=  cycle
To understand the difference : modified / pure sine wave  !
EMJunkie
If an Electrical "Generator" did not exhibit Negative Shaft Torque: T = F · r · sin( θ )N⋅m, then a "Generator" could produce copious amounts of Energy, Joules per second, for very little force on the Shaft. An Above Unity System. However the "Generator" is a Symmetrical System, Equal Shaft Torque is required as M.M.F in the "Generator" Coils. See below image.
All Symmetrical Systems are inherently Below Unity, simply because: Input = Output - Losses.
Asymmetry is required to achieve Above Unity!
With Asymmetry, one gets the following equation: M.M.FInput + -M.M.FOutput + M.M.FOutput = M.M.FInput
This means all your Input is not used! This means the Total MMF is not zero as it is in a Transformer or an Electrical "Generator". The equation being: M.M.FInput + -M.M.FOutput = 0.
If you can realise a few simple things, then your path forward is so much easier.
It is time to wake up, time to make steps forward!
Three Coils, one Input Coil, two Output Coils, it can be done with two Coils, in the right geometry, can very easily produce Output Greater than Unity, an Above Unity Machine!
Best wishes,
   Chris
forest
