0 Members and 95 Guests are viewing this topic.
forest
Chris,
The source of energy in generators is magnetic field. I have no doubt about it. However it might be tricky to proof, which explains why nobody is actively proposing magnetic field as a source of energy.
partzman
Quote from: EMJunkie on March 10, 2020, 05:47:32 PM
Hi Forest, extremely doubtful.
Why? Because Coil Interactions are currently simulated entirely around Symmetry, no Asymmetry is allowed for. Experts in LTSpice or similar, please correct me if I am wrong!
[snip]
Best wishes,
   Chris Sykes
Chris,
Any coil interactions can be simulated in LtSpice unless there is an outside energy source that has not been accounted for.  It all boils down to accurate models so, if you will document the inductance of each of your three coils along with their dc resistance plus, provide the info to allow the computation of all K factors or coupling factors.  This will require 3 K factors to create the proper matrix and this is done on your end in the following manner.
Label your coils as L1, L2, and L3.  Then measure the inductance L1 aid L2 and L1 buck L2.  Likewise do this with the pair L1 and L3 and pair L2 and L3.  From these measurements, the K factors can be calculated.  Label L1-L3 as to which is primary, etc, and be sure to identify which pair includes the load.
Also, is the core gapped?  IOW, is it operating in a linear mode through the peak current excursions.  Non-linear core operation can be modeled but the complexity is much greater.
Also, what is the estimated resistance of your heated lamp load and power supply voltage used.  I already realize you are using an "H" bridge for the switching.
From this info, a reasonably accurate simulation should be possible with waveforms that would agree with your scope shots.
From my bench tests of your device, it is my opinion that the long discharge time in the output current waveform is from stored energy in the leakage inductance but with simulation we would know for sure.
Regards,
Pm
EMJunkie
Quote from: forest on March 11, 2020, 12:40:46 PM
Chris,
Hey Forest,
I use as much reference material as I can. This subject, Changing Magnetic Field in the presence of a Conductor can be verified by one of the greatest Physicist's of all time: https://www.youtube.com/watch?v=XTw4wBfUTNI
If researchers can not accept Fact, then they are not researchers!
Best wishes,
   Chris Sykes
EMJunkie
@Raycathode
I would prefer you no longer post to this thread! I have reported you to Stefan for being a Public Nuisance and Non-Constructive.
Please do not post here again!
Thank You,
   Chris Sykes
Raycathode
Sorry Chris did i say some thing you couldn't answer
Like you hate Jews and you pretty sure im one,
Well please make sure you tell him about that little gem wont you.
Who did you say you are 'Anti-Semitism' as well
But he should be able to see that for him self!
You arrogant bigot! I kiss you! you have earned it
I tell you what you do you drop all this innuendo slagging off and back down
and start treating me like a human being and stop being aggressive two faced little shit.
Or i will report you my self because if you get me chucked off I will make sure I take you with me!
