0 Members and 76 Guests are viewing this topic.
WhatIsIt
Quote from: forest on March 11, 2020, 12:40:46 PM
However it might be tricky to proof, which explains why nobody is actively proposing magnetic field as a source of energy.
https://www.youtube.com/watch?v=5nxKqfkkndw
On the left is few turns (big coil) HV sparking.
On the right is green transformer operating inside magnetic field of HV few turns.
No physical connection between them except magnetic field.
When HV is on, green transformer raise voltage and current.
It is principle of Akula's HV antenna (superposition of fields).
Akula, Ruslan, Oksimoron, Adrijan Dniester, Kapanadze. (all have that HV antenna).
EMJunkie
Quote from: WhatIsIt on March 11, 2020, 05:37:40 PM
Hi WhatIsIt,
Yes, your'e on the right path! The Magnetic Field is actually an Electromagnetic Field, consisting of an Electric and a Magnetic Component at Right Angles to each other, this you already know by the sounds of things.
Recently, I covered this topic on my Forum, I have covered this many times before:
Quote from: Floyd Sweet link=http://www.hyiq.org/Downloads/Nothing%20is%20Something.pdf
THE MOTIONAL E-FIELD
Of all the known fields- electric, magnetic, gravitational and motional E-field the only ones incapable of being shielded are the induced motional E-field and the gravitational field. The nature of the motionally induced electric field is quite unique; in order understand it more fully we must start by parting with a few misleading paradigms.
When magnetic flux is moved perpendicularly across a conductor an electromotive force (E.M.F) is electromagnetically induced "within" the conductor. "Within" is an artefact of the commonly used analogy comparing the flow of electric current within a wire to the flow of water within a pipe. This is a most misleading model theoretically.
The true phenomenon taking place has little been thought of as involving the production of a spatially distributed electric field.
The Magnetic A Vector Potential is however different again. It is an Electric Field, but one with Curl.
This is directly related to this quote from Floyd Sweet:
However, when alternating current is surging through a transformer an electric field surrounds it.
It is important we realise, in a Conventional Transformer, we have 2 Changing Magnetic Fields, the Secondary and the Primary, a Symmetrical System. The Secondary need not entirely oppose the Primary, it can be redirected if we are clever enough to realise this! We can define the Magnetic Field as an MMF, so we have 2 MMF's. It is possible to have three MMF's and the third MMF to Counter the Secondary MMF. This means the Third MMF Assists the Primary MMF, an Asymmetrical System.
See how constructive we can be when we loose the Distractors!
Best wishes,
   Chris Sykes
Raycathode
Hi Sorry about the rant with Cris it needs to stop.
Hasve a look at the photo the one you posted is on the Dally thread I found it a while back
that circuit only works wih one type of circuit at resonance  (re T1000 posted it) I will try see if i can find it.
Sorry for interuption.
It was used with a TVS driver, it's a bit of a suicide device you have to bang the power on it you cant wind ot up
or both transisters switch on at once and blow up. look on you tube i'm sure you will find a how to vid.
Raymondo
WhatIsIt
Yes, the third field could be the answer!
"The furnace which feeds itself?".
Interaction of third field.
Third field, definitely, is making system out of symmetry.
WhatIsIt
Quote from: Raycathode on March 11, 2020, 06:51:06 PM
Raymondo
About the resonance?
Akula in his posts first claims that it has nothing to do with resonance!
Akula post:
A little elucidation  to ensure that you're not getting at any jungle such as
resonances and excitations
This is all interesting but only for experiments !! I
would say different kinds of games!!
Our first and the basic task is to increase the
current !! I see two ways to make this.
First  is when we take some ready voltage
and convert it through the amplifier.
Second when we forming needed voltage right
in the amplifier.
To the point of matter in Kapanadze device main role play the
second inverter - in fact trans of inverter which was placed in the field built by
amplifier.
After a while when he saw money in device, his story turns around,
and he is masking everything with old story of magic and resonance.
The presence of third field is somehow important in all of those devices of
Akula, Ruslan and others.
Resonance is powerfull beast, but there are all kind of resonances.
When they say resonance, it can be anything in their systems,
not essentially what we think at first glance.
