EMJunkie
Quote from: WhatIsIt on April 08, 2020, 05:38:07 PM
Or you can remain king in your castle!
Forever!
Was that necessary? Really? I see what you are trying to do.
Best wishes,
   Chris Sykes
EMJunkie
Quote from: lancaIV on April 08, 2020, 05:29:00 PM
https://en.wikipedia.org/wiki/Grand_Unified_Theory
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4710698A&KC=A&FT=D&ND=3&date=19871201&DB=EPODOC&locale=en_EP
Thus, the present invention realizes a miniaturized version of the switching circuit as disclosed in Japan Patent Kokai No. 189,727/84, but is high in durability, and free of motion noise.
Thanks lancaIV,
Best wishes,
   Chris Sykes
http://jnaudin.free.fr/vta/
  The vacuum triode is a solid state device consisting of conditioned permanent magnets capable of producing a motional field. This field opens the gate to the Dirac Sea where negative energy is able to flow from an into the triode's receiving coils. The coils are very small diameter copper wire but are capable of producing in excess of 5 kilowatts of useful power; this in itself is a clear indicator that the type of electrical energy provided by the device is not conventional. The wire sizes employed by the device would not be capable of carrying such large currents without excessive heat gain, however, the triode's coils actually run cooler when loaded at 5 kW.   The fundamental magnets have been broken free of their binding forces which constrained them to be steadystate single pole uniform magnetic flux devices. They are now able to simply support mass, as demonstrated with the transformer steel illustration. They can now easily be made to adopt a dynamic motional field by applying a tiny amount of excitation. Specifically, 10V @ 1 mA (10 mW) of excitation at 60 Hz. will enable the coils of the triode to receive from the Dirac Sea in excess of 5000 watts of usable negative energy; how much more can safely be removed has not yet been determined.
The question is : did he thought and explained about a. 5000 Watts average output or 5000 Watt peak DIRAC-surges output
10 V 1 mA 60 Hz  = 10 mW          to 5000 W  ?Hz
http://jnaudin.free.fr/vta/vtabuild/index.htm           here to read about output : up to 1,5 KW at 60/50 Hz
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1
Such an energy converter consisting of two electrical coils with a common magnetic or magnetizable medium in between is usually referred to as a transformer. Such an energy transformer can be fed with a sinusoidal alternating voltage having a mains frequency between 16 2/3 Hz and 60 Hz. Such transformers have the disadvantage that- they have heat losses in the energy transfer which are known under the designation of copper and iron losses and which adversely affect the efficiency of the transformer. Transformers used in this manner are capable only of converting the electric energy supplied into magnetic energy and subsequently of converting said magnetic energy back into electric energy of different voltage and current. The electric energy delivered is in this case always less than the electric energy supplied. In electric energy transfer, it is avoided to use a frequency which lies around and near the natural nuclear magnetic resonance frequency of the transformer since at this frequency the electric energy absorbed increases sharply with the electric power delivered being the same, and this would mean a considerable loss in efficiency.
Investigations relating to the mechanism which causes the sudden increase in the energy loss on reaching the magnetic core resonance frequency of the transformer have resulted in the discovery of the opposite phenomenon. Namely that the electric energy absorbed suddenly decreases markedly with the energy delivered remaining constant on reaching the magnetic core resonance frequency if the transformer and the electrical signal supplied have certain specific properties. The fact is that <">in that case it has emerged that the transformer absorbs energy from the surroundings and converts this ambient energy into electric energy so that the total quantity of electric energy delivered is greater than the electric energy supplied.Figure 15 shows a diagrammatic reproduction of the three essential components of this third embodiment as a magnetic core resonance converter, viz. a signal generator 73, an energy absorption transformer 74 and an electronic frequency converter 75. Electric enerlgy, for example 220 V/50 Hz is supplied to the input 71. This power is processed electronically in the signal generator 73 to produce a signal such that magnetic nuclear or core resonance is produced in the magnetic medium of the energy absorption transformer 74 when the latter is fed with said signal.
To clarify the operation of this embodiment according to the invention, the following dimensioning of the transformer windings is given using Figure 17 as an example, the iron cores being dimensioned in accordance with the manner usual for transformers:
- winding 81: 1000 windings, 220 V/50 Hz, 5 A at full load;- winding 82: 1 winding, 5000 A;- winding 84: 1000 windings, 5000 A; - winding 85: 1100 windings, 4500 A, 220 V/50 Hz.From the above example it is evident that, with a coil 82 having 5000 ampere windings, a flux variation of 5000000 ampere windings can be generated with the superconducting coil 84.
Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1 . 1 kW, and this corresponds to a power gain of approximately a factor of 1000. In the variant indicated in Figure 18 of this fourth embodiment, a two-phase system has been assumed. In a further variant of this embodiment, the latter can also be constructed according to a three-phase system. In the above described variant, a mains frequency of 50 Hz has also been assumed. These embodiments may, however, also be used for other frequencies.
EMJunkie
Quote from: lancaIV on April 08, 2020, 06:02:08 PM
Magnet Conditioning is a Hoax, a Lie!
Look for specifically, key terms!
1: producing a motional field
2: triode's receiving coils <-- Plural!
3: a dynamic motional field
Key terms, terms that every single Electrical "Generator" has ever used, are present! There is no Magic here! Its very conventional, EMF, measured in Volts, is the what is "Generated" when a Conductor is exposed to a Motional Magnetic Field...
Critically, the Magnets cannot produce an EMF in a Coil, if the Magnetic Fields are uniform across the face of the Coil, which, critically, they were in the VTA! Simply, the Magnets themselves did not create the Voltage! Its impossible!
Experimental Proof: https://www.youtube.com/watch?v=8tTQ727ZHIU and https://www.youtube.com/watch?v=EcNEvRuH9EQ
We can prove the magnets were NOT altered in any way! It is simple to prove this! The Razor Blade experiment proves this, Image again below:
Facts, Facts can not be disputed.
Best wishes,
   Chris Sykes
piezo-/pyro-electric ! Voltage by material stress
"permanent magnet" conditioning is seldom a hoax when we discuss about industrial produced "permanent magnet"-s ! Not natural !
Enforced pulsative Barkhausen Effect repeating process ?!  https://en.wikipedia.org/wiki/Barkhausen_effect
