0 Members and 46 Guests are viewing this topic.
I have now tried _all_ the Horizontal deflection transistors I listed, with the exception of the ST 2001HI which does not have an internal diode. Most "work", some oscillate improperly, some clip the negative going portion of the ringdown. The ones that "work" produce high-amplitude spikes, even greater than 3kV, _when properly driven_. All require a lot more drive from the FG than the mosfet does.
My Interstate F43 FG is capable of a lot more drive output than most modern FGs, remember.
The scopeshot from EMJunkie shows an _underdriven_ transistor. Here are two quick screenshots from my test with the 2sd2539, simply subbed into the socket of my testbed. Recall that I have a 100K pulldown resistor from Base to Negative Rail. The shots are taken at 6.7 V in from the power supply, and are shown at 200 V/div vertical scaling, with the 100x probe connected to TP A (the top of the load/CVR combo). Test is at approx. 1.73 kHz, FG is isolated.
The first one, most similar to EMJ's, is with inadequate drive from the FG.
Second one is with more drive.
PIH123
Quote from: TinselKoala on February 05, 2015, 04:59:23 PM
So tell me which one of these is "close enough" so that I won't be _wasting my time_ following WRONG SCHEMATICS trying to replicate BAD MEASUREMENTS.
I refer you to page 61 post 905
1. What is the exact circuit under test ?
2. What are the component manufacturers and part numbers used ?
3. Where you sourced them would be useful but not required.
4. What equipment did you use to test ?
5. What settings on that equipment ?
6. Where was that equipment connected to the circuit.
He replied that he was not interested in providing that info until people "Understood" what effects were going on.
Six pages later, same old, same old.
He was here to teach remember, what a joke.
Oh, and by the way, he has wasted nobody's time because you are doing this voluntarily.
You are a "greedy selfish person" if you want this info (post number 911).
Here's another shot with the 2sd2539. Top trace is the TP A voltage, 50 V/div, 100x probe. Bottom trace is the FG signal, 1 V/div, 10x probe. This is _severely underdriving_ the transistor, which is causing the lower amplitude group of ringing between the larger groups. Horizontal scale is 100 microsecs/div.
EMJunkie
Quote from: ramset on February 05, 2015, 05:18:19 AM
Tinsel
your time and efforts are greatly appreciated here ,your willingness to explore and
experiment are a tremendous asset to this community,especially when combined with constructive input.
some of us are going to try to get your equipment from Canada
so you can do even more here,also I have read that you need a Scope [about 400.00].
Note **we already have some financial commitments for this equipment move from Canada
still more needed , many hands make light work.
and the newer scope is a recent development .
any parties interested in assisting us in this venture please PM myself or Mark Dansie
or Email ChetKremens@gmail.com
with the proper equipment some very interesting Things can be explored
right here ,and perhaps some new text can be added to the books....
respectfully
Chet
PS
I might add ...Many persons wish they could explore and experiment at the level being demonstrated here...
we cannot all be skilled in all fields,but we can do our part by supporting Men that have the skills to do the experiments in an honest and sincere fashion.
There are some really interesting experiments that need doing ,this stressing the fields as well as the cores and doing what seems counter intuitive has Merit.
here we have SOME cooperation ,  it is a very nice model and it works ....
please help,....we can make this MUCH better.
TK, Chet and ALL - This can be improved on tremendously! It doesn't work with just Square Wave input, but this is where we see more effects!
If we all Band together, with all our out expertise in the areas that we all have, then yes in a few Months time we could ALL have working devices that are tremendously better than what we have just seen!
Please ask, Where does the Spike/Ringing come from!
Quote from: PIH123 on February 05, 2015, 05:44:56 PM
I am "voluntarily" examining some claims, that is true. If I am given outrageously wrong information with which to conduct my examination... then I am wasting my time, and yours too.
