Have broken the magnetic code for extracting energy from magnetism
Started by gammarayburst, January 21, 2015, 02:56:57 PM
sm0ky2
perhaps I can shed some light on what's going on here... maybe not, but i'll try...
the magnetic domains in the first pair of bars, is under influence of the magnets, since the bars are flush together, this translates into an induction effect in the second pair of bars. the magnetic domains are 90-degrees out of phase to the first pair.
  by this is mean, as per the drawing, South pole is on the first pair, this creates a N/S domain through the pair in a vertical axis.
    the second pair, is induced North on the left side, where it touches the first pair of bars, and South on the right where it touches the third pair.
this is because of the stronger flux through the top of the magnetic domain, caused by the MAGNETS, not by the field lines in the first pair of bars.
Now,.. when the magnets slide onto the second pair of bars, the magnetic domains switch, 90-degrees, caused by the stronger field of the magnets. this "overrides" the existing induction, causing the bars to repel from each other.
This can be demonstrated by performing the described set-up.
what I can't figure out is how he plans to switch onto the 3rd set of bars, which are no longer "flush" with the second (separated) pair.
also,. there is some work, imparted to remove the magnets from the second pair of bars, which, may overpower the work gained by the repulsion between them.
That's my thoughts on this,. hope it helps.
