2nd law violation:new battery type "poor man's Karpen"
Started by jonfrommanahawkin1, January 29, 2015, 02:14:56 PM
jonfrommanahawkin1
A little bubbles isn't uncommon but it should stop but you shouldnt use any special water.
tap water
if the water doesn't have the right balance it will try to leach minerals from the anodes. That's what the bubbles are and a block in your mix is bad as well
Take room temperature water and mix in borax as a powder till the water won't except it anymore and it becomes cloudy and you see a pile of borax form at the bottom.
like your making chocolate milk and you want it very rich
but that current is way to high that water is way to acidic
And yes jersey
All the best
jon
jonfrommanahawkin1
I'm uploading a video now to help. It won't stay up forever but  it will till I can do a proper video
jonfrommanahawkin1
Pomodoro,  you do realize that what you did is the exact opposite of what I've been telling everyone. Deionized water has the minerals removed. Not to mention, if you have water that has borax in it that eats up magnesium I highly recommend not consuming it at any level.
so I'm thinking you're deliberately trying to fail the experiment.  But I'll test my water to be sure and so everyone can have the right readings they need .
And I would also like to point out that I'm already getting positive feedback from others that refused to comment because of trolls like you
Jon
jonfrommanahawkin1
And also you don't know how to messure a battery, the voltage isn't a short and either is an amperage reading,  open a automotive service guide and read the batter test.
the total voltage on theterminals will help you determine if one of the cells in the battery is bad. taking an amperage reading across the terminals will tell you if the battery has cold cranking amperage to help determine if the battery needs recharging, a load test will also help before and after recharge.  Then if you put your meter in series (that's where you use the positive and the negative of the meter to complete the circuit with the car) and find a reading then you can determine if a car has a parasitic draw (what circuit is still on in the car)
But you should know that right? You're not building a circuit board, it's a battery the readings tell you different things about what you're doing.
Jon
jonfrommanahawkin1
Pomodoro,  are you sure that's even borax,  it looks home made. Did you do the crystal growth right? Or did you contaminate it when you changed its container?
Jon
