2nd law violation:new battery type "poor man's Karpen"
Started by jonfrommanahawkin1, January 29, 2015, 02:14:56 PM
dieter
I thought it's a dry cell, and wouldn't simple nitrogen from air act as an acid in a galvanic process?
However, I would like to do some experiments with gold leafes that I got, 23.99 carat, if it' s only the anode that corrodes, what would you try as the other element?
I have no access to magnesium ribbons, but I got pure graphite, could that work, gold+graphite?
BTW do you have a link to that potential table you showed? Thanks.
BR
BTW2. Nothings wrong with a patent if you really got a good, new battery.
pomodoro
I'm bandwidth limited so could only watch a little of the video. I saw a magnesium strip and a nickel strip, what are you claiming exactly, is it power without corrosion?
jonfrommanahawkin1
That's exactly why I state my battery as two dissimilar metals in a non-reactive electrolyte because it will work with any two.
I wouldn't use the gold but I would use the carbon and if you don't have ribbon the next step up is zinc or or aluminum the hardest part is finding a non-reactive electrolyte. The simplest one to use is tap water not distilled because distilled will leach the minerals it need to equalize its ph
plus carbon is higher on the chart then gold
To find the chart simply Google Galvanic scale and you'll see the same or similar charts I use in my video.
If you're good with balancing chemical equations you can try different electrolyte reaction till you find one that won't balance or form a new compound and then it will make exactly what I've made
And fyi carbon and magnesium will be my final design because carbon is cheap and magnesium has the highest potential.
jonfrommanahawkin1
Yes pomodoro,  I think it's power comes from atomic spin or movement. But I can't be sure. And because the electrolyte is a molecular reaction which I'm claiming is part of a different system then an atomic system technically I'm not violating the laws of physics
jonfrommanahawkin1
I should point out that at this point with atomic systems and molecular systems I'm referencing  Nassim Haramein work on the holographic universe
