Thanks to ALL for your help!!
crystal radio: the first real free energy device
Started by franco malgarini, February 16, 2015, 04:52:26 AM
gyulasun
Quote from: telecom on March 13, 2015, 12:19:57 PM
High-intensity ionizing radiation in air can produce a visible ionized air glow of telltale bluish-purplish color. The glow can be observed e.g. during criticality accidents, around mushroom clouds shortly after a nuclear explosion, or inside of a damaged nuclear reactor like during the Chernobyl disaster.
http://en.wikipedia.org/wiki/Radiation_damage#Effects_on_gases
You seem to compare an elephant with a mouse.
Of course a high intensity radiation in air can surely produces what is described, no doubt.
In the spark detector video the particle source is nowhere near as strong as would be needed for those spectacular phenomena associated with high intensity radiation, this is why a HV supply was used.
It is interesting you disregard all what I wrote.  Please do experiments and come back how the current draw of a HV supply increases when you place a particle source near to an airgap and the airgap fires as shown in the video.
Gyula
telecom
Quote from: gyulasun on March 13, 2015, 01:31:19 PM
Gyula
Ionizing properties of radiation were discovered in the 19the century,  remember the experiment with  electroscope???
pomodoro
It all boils  down to this: No matter how many zillions of ions and electrons the alpha makes, you can't make them form a current of their own to power a load. You can't direct them using a potential and get a current just from the ions/electrons through a load.  There are some alpha voltaic and beta voltaic patents but the power is negligible. Try it your rock, if you succeed, you will have achieved something great.
Edit, I'm not if the circuit below could work. Will the big plate shield the field from the smaller plates or will the zillions of ions and electrons be attracted to the plates and power the load? Will any current be drained from the supply?  In any case something like this is what you need, you cant have the 8000V directly powering a device with the aid of the ions/electrons.
gyulasun
Quote from: pomodoro on March 14, 2015, 12:26:43 AM
I think that is correct.
I think it all depends on how many particles are able to penetrate through the big plates. The more of them can, the higher the current draw from the 8000 V supply becomes.
I editied your drawing to make the wires appear with a better contrast.
More or less, your drawing resembles a kind of multielectrode electric valve like a pentode where the outside supply voltage is between the anode  (+ in your drawing and the cathode (- in your drawing) and 'big' plates could be the supressor grid and the  screen grid.  OF course the alpha particle source would replace the electron emitting real cathode of this pentode.
Gyula
