fun observations about the magnetic field
Started by superhero, February 20, 2015, 07:06:36 AM
superhero
1- The magnetic vortex revelation--watch the real shape of the magnetic field
http://youtu.be/wR7c4iXum-A
Also http://youtu.be/ZViJ2WtFN8A
2-The effect of lenses on the magnetic field
Horizontal lens (Parallel to earth surface )
http://youtu.be/9CJ8TPjL9t8
Vertical:
***### When the lens is placed in a vertical position (perpendicular to the Earth's surface), the magnet rotates clockwise in The upper side of the lens and counterclockwise in the lowe side. This is a mind twist please any     explanation.  ***###
http://youtu.be/pPIdEe7GY5g
Extra
http://youtu.be/11A1A56Mr6E
3-the effect of spin on the magnetic field
http://youtu.be/8C6uyQ0bct4
4- magnets with repulsion and attractions simultaneously
http://youtu.be/ktX1VqVnbys
http://youtu.be/LyvfDzRLsiU
5- the beauty of spin (free energy)
http://youtu.be/b-MSiQTXIG0
6- the famous primer fields theory
http://youtu.be/9EPlyiW-xGI
7- the infamous Ts9 magnetic shielding
http://youtu.be/SQw-nk6nYs0
8- simple V gate energy device
http://youtu.be/nKrWZKh-i08
I thought i'd share my memorable magnetic field moments with you all.  Enjoy
Low-Q
I'm afraid there is nothing special about these videos. The experiment with the CRT screen and its behaviour in the precence of a magnet is predictable. The electron ray fails to hit the right color, and instead are deflected by the magnetism. Also this electron ray is moving horizontally very fast and its magnetic field will respond to the field from the magnet and cause the screen to swirl.
About the "vortex" in the last video, and the lense experiment. The reason why they rotate is because one side of the magnet is closer and has most friction to the surface. When the handheld magnet moves, the "free" magnet will ofcourse starte to rotate.
Put one magnet on a needle bearing for least friction as possible, and see if that magnet starts to rotate in presence of another magnet. It won't.
Magnetism has no vortex. That is what I try to say.
Vidar
synchro1
@TinselKoala,
What do you make of this?
https://www.youtube.com/watch?v=IljUwQGEkGo
Quote from Dr. Stiffler:
"Just wanted to show this short video on how field arrangements of permanent magnets can be so arranged to obtain motion with no external energy input".
Vidar, you are right on.   The first clip that you linked to is from "Al" a.k.a. "ACCA" on this forum.   His magnet/CRT tube and his aquarium/bubble vortex clips are all totally wrong.  It suggests this:
Challenge to Al/ACCA:  The challenge for you is to actually understand what you are looking at in your clips.  Why don't you pick one and we will collectively figure it out together.  However, you will not be spoon-fed the information.  You will be asked to research and understand the basic fundamentals of electronics for yourself, and then apply them to your experimental observations.  If you are up to the challenge then I would suggest that you pick your favourite "aquarium 'vortex'" clip.
