Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
Thanks syncro, i think I have many enemies as zerofossilfuel, and other people that are jealous of my work for me is only fun ..! this motor believe or not.... is a great motor 100% efficient...! if you don´t like the circuit first do it and second comment....!
Arthurs
Hi Skycollection
I follow your experiment replication, Using normal coil, and Unifilar pancake coil, Bifilar pancake coils, Were carried out comparing drivers to pick up and power
Concluded that:
Whether Unifilar pancake coils, Or Bifilar pancake coils, Their effects and normal coil identical, Without the slightest increase efficiency and improve.
Driving efficiency and normal coil performance is identical;
Lenz resistance and normal coil performance is identical;
Generation efficiency and normal coil performance are identical.
May have offended you, but you can also use the normal coil for comparison.
skycollection
Hi Arthurs.....NO DOUBT about conventional coil but.....PANCAKE COIL HAVE INDUCTIVE COUPLING EFFECT, PANCAKE COIL IT IS EASIER TO ENTER IN SELF OSCILLATION, I CAN INDUCE THE VOLTAGE IN SEVERAL PANCAKE COILS....MY QUESTION IS: CAN YOU MAKE A SEPTEFILAR CONVENTIONAL COIL...? I AM STUDYING THE PANCAKE COIL FOR YEARS AND I DIDN´T FIND THE END THE TUNNEL...!
I can see amazing work in your coils and i would like that you can make the experiments that i can´t do because i have no technologics implements, i hope you can measure your motor and post the results on youtube....! i send you a photo of my pancake coils and i will apreciate any result you have, i apologize for my bad english, i don´t speak english but i have two eyes and brain.
saludos from mexico
jorge rebolledo
skycollection
You can see the photo of the pancake coils, all the groups in series are insulated and divided, for example the SEPTEFILAR COILS consist in six groups of six pancake coils in series, all the pancake coils don´t have contact with the other groups, every pancake coils groups are individual pancake coils, the voltage is "induced" to the other groups of pancake coils, only one group is connected to the circuit...!
Arthurs
Hi Skycollection
Thanks reply
I'm very interested in your experiment,Because of this,As you can see:My replication very carefully,I also hope I can replicate the success,My success with replication to verify your findings.
Right now.
Add pictures,Description coil assembly and connect my replication.
For the pancake coil,Between each pancake coil and the surface has a polyimide insulating film professional electronic products used(Certainly there is no normal coil).
I really feel replication without error,
Please correct me,
Thank you!
PS:
In order to allow binding between each pancake coil closer,Induction better,[size=78%]When I experiment,Each pancake coil lead wires are led out from the inside and the outside and connected to each other,If you do not,Will there is a gap 0.8mm (AWG 20) enameled wire between each pancake coil.[/size]
