Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
Quote from: Arthurs on March 31, 2015, 08:21:56 AM
Use "AA" batteries as a power source,
Does not explain the weak supply capacity,
For example: DURACELL "AA" battery capacity can reach more than 1700mAh,
So: Use "AA" batteries as the drive power can not explain the input power is small.
Thus: To know the exact input power,
Must be connected to the meter drive circuit monitors the input voltage and current.
@Arthur,
The apparatus appears as though it's benefitting  from "Reverse Lenz Propulsion". Normally the increased light intensity would cause the rotor to experience deceleration rather then speed up. Secondly, the induced current in the closely adjacent bifilar secondary's  is inverted to AC from DC pulse in the primary. This causes gain measured in "Negative Micro-Henries" due to the zero impedance to change in current direction.
Consider this:
"In pulse transformers one of the windings of a bifilar coil is used as a means to dissipate the energy accumulated in the magnetic flux. Because the two coil windings are so closely spaced, they are penetrated by the same magnetic flux. One of the wires is usually grounded using a LED. So when the voltage on the other main wire is out, the magnetic flux generates current using the auxiliary (limiting) winding. The voltage on this winding is equal to the voltage drop on the diode (forward direction). Voltage of the same value appears on the main winding. Had the limiting winding not been used, the parasitic magnetic flux would have tried to induce the current in the main winding".
skycollection
https://www.youtube.com/watch?v=pSz4Xz7pJwY
Arthur, i have no secrets for you, i am trying to help with diagrams and with videos, you can see how to make pancake coils part one, the way to wind the coils and easy way to make it in 08 minutes, i hope it serves for you...! you can make single pancake coils or bi-filar pancake coils, the shape and size you want, small coils or big coils.
tinman
Quote from: synchro1 on March 31, 2015, 08:41:04 AM
@Arthur,
QuoteThe apparatus appears as though it's benefitting  from "Reverse Lenz Propulsion". Normally the increased light intensity would cause the rotor to experience deceleration rather then speed up.
And why do you think that?. If you knew what was happening,then you would understand as to why the rotor speeds up when a heavier load is placed on the coil/inductor. A heavier load means a greater current,which means a stronger magnetic field,which means a greater attraction or repulsionforce (depending on wether it's a repulsion or attraction motor setup)  on the rotor magnets.
QuoteConsider this:
Consider this-->current follows the path of least resistance.
Quote from: synchro1 on March 31, 2015, 01:21:33 AM
@Milehigh,
The "Series Bifilar Coil" of Nicola Tesla is an AC coil. The coil has zero impedance to change in current direction. Running AC current through a "Single Wire" coil of equal Ohmic resistance will cause it to heat up while the "Bifilar" runs cool. Testing the two types of coils for comparison with a monopolar rotor or DC current will not produce any meaningful results.
That is not true.
http://www.youtube.com/watch?v=OcFySCAxLzs
synchro1
Quote from: TinselKoala on March 31, 2015, 11:24:57 AM
That is not true.
@TinselKoala,
Up to your old tricks again, huh?
Your video compares the "Hairpin Bifilar" to the "Tesla Series Bifilar" coil. What I challenged you to do is to place a single wire pancake coil on a Gegene hot plate and record as small a rise in heat as JLN does with his TSBC. I offered to bet you any amount of money you couldn't accomplish this. This comparison has nothing what-so-ever to do with your "Hairpin" to "Tesla Bifilar" comparison video.
https://www.youtube.com/watch?v=JqgO7AEZXzI
You know as well as I do that the Gegene would melt the single wire pancake coil rather then inductively couple and transfer the AC power like the "Tesla Bifilar Pancake" does.
You're just in that group of "Haywire Trouble-Makers"!
