Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
As you know i don´t speak english well, i am learning, and i hope you have some time to make a "drawing" of your idea about the REED SWICHT, i would like to make more experiments, i understand with drawings, and i would like you can make the example and the components, i will make the experiment....! thanks for your time...!
synchro1
Quote from: skycollection on October 07, 2015, 11:52:33 PM
@Jorge,
Los 120 voltios A.C. corriente pasa directamente por el A.C. "Reed switch" conectado entre lo uno y lo otro alambres de la bobina y la toma de corriente eléctrica. No es importante cual lado de la bobina usted elege. Es muy sencillo! Hay nada mas. Lo siento, no puedo a dibujar ahora. Yo intentare mana~na.
synchro1
@Jorge,
This is an A.C. electromagnet attraction motor with an iron ferrite rotor. When the passing trigger magnet positioned on the rotor closes the "Reed Switch", the A.C. wall current creates a strong oscillating magnetic field in the multifilar coils that attracts the iron ferrite rotor equally with both polarities. These bifilar coils heat up less from A.C. current then the single wrap type! This is the most outstanding singular advantage of the Tesla series connected bifilar coil:
This coil design of Jorge's is very close to the giant A.C. scrap yard magnet Westinghouse manufactured and sold after acquiring the bifilar pancake patent which helped make Tesla rich. This is over a century old antique! This is the first motor of it's kind that I've ever seen based on the coil's original pourpose as a "Coil For Electro Magnets" as stated at the top of Tesla's patent below:
skycollection
Do you think that your idea it works ...? do you think that the current of the first coil "induces" the current  coil to another coil...? ok, the only way to know is with an experiment, let me try and i will anwser you soon...!
skycollection
Synchro1 Sorry my friend, your experiment it doesn´t work, there is not induction of current one coil to the other coil, is for the kind of current....! my pancake coil works ONLY with AC CURRENT...!
Saludos jorge
