Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
With this experiment i will show you that is not a "trick" is just inductance, is "the inductive coupling effect"....!
https://www.youtube.com/watch?v=A3NioI-m5EM
saludos from mexico
synchro1
Quote from: skycollection on November 11, 2015, 08:51:58 PM
saludos from mexico
Skycollection tested the inductance oscillator with one, then five bulbs and timed the capacitor discharge. The voltage divided between the five bulbs, but the amperage remained unchanged. This implies that the number of possible inductance coil bulbs should be directly proportional to the voltage, and that the amperage would remain constant regardless. A very efficient way to magnify power!
This is an overunity power plant!
synchro1
This is a 5 volt D.C. to 12 volt D.C. voltage doubler circuit:
The inclusion of this kind of simple circuit would allow Skycollection to increase the number of coil bulbs to twenty with equal luminosity!
synchro1
China burns too much coal. The particulate matter over the Pacific Ocean has caused a severe drought in the State of California. It would help everyone if China mass produced a free energy generator.
synchro1
There are lots of ways for Skycollection to handle the voltage doubling from his D.C. Power Source to illuminate additional bulbs with equal intensity. The circuit below boosts five D.C. volts to twelve D.C. volts; Skycollection would need to connect four "AA" batteries in series to reach the five volt minimum, or 3 or 4 10F 2.5v caps!
Here's the specs on his 2N2222 transistor:
Type Designator: 2N2222
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.5
Maximum collector-base voltage |Ucb|, V: 60
Maximum collector-emitter voltage |Uce|, V: 30
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 0.8
Maksimalna temperatura (Tj), °C: 175
Transition frequency (ft), MHz: 250
Collector capacitance (Cc), pF: 8
Forward current transfer ratio (hFE), min: 100
