OVERUNITY CIRCUIT ??
Started by magnetman12003, March 09, 2015, 05:30:10 PM
Quote from: magnetman12003 on March 09, 2015, 05:30:10 PM
Hi All,
Here is a circuit I put together that allows a small electrical force to transform into a large electrical force.
The transistor and coil take 24 volts and low amps to operate.  When that happens a 2 inch diametric ring magnet with huge flux lines starts spinning over the coil.
The flux lines cut through the coil and generate hi frequency, hi power voltage and current.
That is sent to a full wave rectifier circuit that turns it into DC voltage and enough current that could kill you. A capacitor stores the charge.
The NEGATIVE terminal is common to both input and output.
So a little bit of electrical energy produces a lot of electrical energy using mechanical action or magnet spin.
Double click the diagram for a larger view.
(removed a bad link)
Well, I for one would love to see this diagram that Senior Member Magnetman12003 has tried unsuccessfully several times to post. I can think of a few reasons why he hasn't kept trying, using some method that works, or why he hasn't contacted any forum members by PM for help doing it. Perhaps some of then are even more likely than "government suppression" or shocking himself to death.
Of course I myself have many circuits that could charge a capacitor up so that it could provide a lethal level of voltage/current, using magnet spin or mechanical action.
But I'm always interested in circuits that do this:
All of my circuits simply store up small chunks of electrical energy over relatively long time periods, that then can be released all at once in a shorter time period. They don't actually _produce_ a lot of electrical energy that wasn't there in the first place.
I'm just trying to be reasonable here. I'd happily build and test such a circuit myself and issue complete reports on my findings, as I've done in the past for other circuits for which similar claims have been made. But I really need to see a complete schematic and description of the operation, along with the measurements that led the claimant to make the claims in the first place, in order to begin work.  It really isn't that hard to post such diagrams and data here... is it? So there must be some other reason besides mere difficulty in posting going on.
magnetman12003
Hi All,
I hope this jpeg schematic works.
https://web.mail.comcast.net/service/home/~/?auth=co&loc=en_US&id=1071005&part=2
I see that it still does not work and I posted a JPEG which still did not show up.   I am not making any claims for the circuit but I will tell you that it delivers over 300 volts and enough amps to continuously light up a 7 wall led 220 volt lamp.
Pirate88179
No, the link does not work.
Hi All,
THE LINK DOES NOT WORK, BECAUSE IT IS A LINK TO YOUR EMAIL. IT MAY WORK FOR YOU BECAUSE YOU HAVE THE RIGHT COOKIE AND THE EMAIL PROVIDER RECOGNIZES YOUR COMPUTER'S IP ADDRESS AND THE COOKIE.  IT WILL NOT WORK FOR ANYONE ELSE, AS YOU HAVE BEEN TOLD ALREADY.
YOU HAVE BEEN TOLD SEVERAL TIMES HOW TO POST AN IMAGE DIRECTLY ON THE THREAD. SEVERAL PEOPLE HAVE ALSO OFFERED TO HELP YOU POST THE IMAGE. IT IS NOT HARD TO DO. SINCE YOU ARE NOT DOING IT PROPERLY IN SPITE OF ALL THIS INFORMATION AND OFFERS TO HELP .... WHAT IS THE APPROPRIATE CONCLUSION TO BE DRAWN?
MarkE
Quote from: magnetman12003 on March 14, 2015, 06:34:42 PM
Hi All,
I've got tonight's winning lottery numbers available in advance:  https://web.mail.comcast.net/service/home/~/?auth=bitemyabacha=enUS&id=1071108&part=4.  Hurry up and use them to buy your ticket before the drawing.
