Overunity motor, part3, all 4 recharging bats reading at 1.400 volts now.
Started by stevensrd1, March 17, 2015, 08:44:46 AM
tinman
Quote from: minnie on March 21, 2015, 12:41:22 PM
  To the likes of Floor and sm0key,
                MarkE , TK, MH  etc. are trying to educate, read and learn before making
   comments, everything they say can be verified. If any of them err and you point
   out they'll retract or amend as necessary, we should all be on the same side!
               John.
Indeed,but dont always asume that the guru's know everything,and if you feel that you are correct,then stick to your gun's-just as has happened here in this thread.
Quote MarkE post 47-Guess what?  I disagree with your claim that L1 is not coupled to L2.
Quote TinMan post 49-Have you heard of the Miller effect capacitance ?
Quote MarkE post 54-Yes, and if you understood it in relation to this circuit you would realize that Miller capacitance suppresses switching:
Quote MarkE post 81(after MarkE took the time to look a little closer)-This tells us that Tinman was right that Miller capacitance is the energy source.
So as you say Minnie,they'll retract or amend as necessary,but if you feel you are right,then stick to your gun's. I will say though,i am yet to see a resonant JT in action,but that dosnt mean one dosnt exist. Maybe a combination of the right core material,turns of the right size wire,and maybe a small cap across the driven coil might hold a chance of true resonance-but lot's of experimenting would be needed.
tinman
@ MarkE,TK,and MH.
Insted of saying rubbish,how would we go about building a resonant JT,or makeing my circuit opperate as it dose,but with a much higher power output?.Maybe a small cap in series with a diode across the collector/base?.
minnie
   Tinman,
            Thanks for your response. I know TK fairly well by now and he's always
helped me, using his own time and money. You can't ask for more than that!
  Thought for the day, nobody really knows gravity. There's still a fair way to go!!
            John.
tinman
Quote from: minnie on March 21, 2015, 01:59:08 PM
   Tinman,
            John.
Gravity-the attraction of two masses of atoms.
Electric field-the atomic differential between two masses.
Magnetic field-a secondary result of the electric field.
Well thats my theory anyway.
Quote from: tinman on March 21, 2015, 08:34:34 AM
TK
Remove the 220 ohm base resistor,and you have my original circuit.
Not quite. My ferrite-cored coils are much lower in DC resistance than the air-core coils you used, and the BC33-25 transistor is very different from the 2n3055. But nevertheless we seem to have similar functions.
Here's a scopeshot that I just took, from the transistor Collector referred to the Emitter. It is essentially identical to MarkE's one-LED scopeshot from his breadboard build.
