Thanks to ALL for your help!!
Fifty Quadrillion Dollar Energy Discovery Suppressed!
Started by gravityblock, March 24, 2015, 03:32:38 AM
gravityblock
The LFTR's waste heat can be used to desalinate sea water.  Extracting natural gas from the ground releases radon, which is radioactive.  The process of using coal also releases radiation.  The current energy technologies based around coal and natural gas are releasing thousands of times more radiation into the environment than current nuclear reactors.  The radioactive waste materials from conventional nuclear reactors being stored can be used as fuel for the LFTR's and completely burned.  I believe the LFTR's would be nearly as safe as LENR's that produce no detectable radiation.
Gravock
memoryman
gravityblock
Quote from: MarkE on March 24, 2015, 07:54:51 AM
LFTRs are still steam boilers, but can produce high temperature steam.
Here's a diagram for the LFTR's showing how the cold in and hot out can also drive turbines in addition to the gas turbines.  You saying LFTR's are still steam boilers, is only based around the poor design of conventional nuclear reactors.
Gravock
gravityblock
gravityblock
Quote from: MarkE on March 24, 2015, 03:04:25 PM
Gas turbines are not really relevant here because there isn't a combustion chamber.  Exchange fluid heated by the LFTR runs what would be the second stage of a multistage gas turbine set-up.
Here'a another diagram showing a closed cycle gas turbine for the LFTR's, and you say it's not really relevant here, lol.
Gravock
