Gadolinium Magnet Generator.
Started by synchro1, April 03, 2015, 02:02:04 AM
profitis
COMPARE BACKSPIKE SPARK SIZE with nickel coins spark size
profitis
'Would the
GD return to a perm mag after rising above its curie?'
No ways no
ekimtoor1
@profitis - yep sure thing. Can you give me some guidance?  Like wire size, wind around the circumference or the diameter, etc. ?
profitis
Use wire obtained from a toy motor ekim.that way it will be lots of turns AND it will be laminated.burn the two tip-ends of the wire with a cigarette lighter briefly to de-laminate the ends for contact to battery poles.try a cellfone battery,try a 1.5 torch battery,try a cellfone charger plugged in wall with phone-pinplug cut off.just slip the gadi coin out of the coil and shove in a equal size nickel coin to test if you get a spark for the comparrison test.wrap wire flat-tight around those coins so that its almost pancake-like.you can also try turning wire around a empty plastic or cardboard shell so that the coin can simply slide in and out
profitis
Use lots and lots of turns of wire
