Rosch taking orders on OU Bouyancy device.
Started by ramset, April 26, 2015, 09:52:03 AM
0 Members and 80 Guests are viewing this topic.
From the IBT link:
The researchers explain that the reason why Shawyer's EmDrive models and EmDrive experiments carried out by Chinese researchers had been criticised in the past was because none of the tests had been carried out in a vacuum.
Physics says particles in the quantum vacuum cannot be ionised, so therefore you cannot push against it, but Nasa says Shawyer's theory does indeed work.
"Nasa has successfully tested their EmDrive in a hard vacuum – the first time any organisation has reported such a successful test. To this end, Nasa Eagleworks has now nullified the prevailing hypothesis that thrust measurements were due to thermal convection," the researchers wrote.
Nasa says its researchers joined forces with a large community of enthusiasts, engineers, and scientists on several continents to discuss EmDrive theories on the NasaSpaceflight.com EmDrive forum, and "despite considerable effort within the NasaSpaceflight.com forum to dismiss the reported thrust as an artefact, the EmDrive results have yet to be falsified".
But... from the NASA blog forum:
QuoteA bit of clarification:  The Eagleworks crew hope to have the 1.2kW magnetron teeter-totter test-rig up and running by the END of June or perhaps now the first couple of weeks of July 2015.  At the moment we are in the middle component procurement & fabrication, and that task is taking longer than expected due to mill breakdowns in the NASA fabrication shop and the usual supply vendor's taking their time to fill and ship orders.
Best, Paul M.
ramset
Mark E
GIGO you use it like aftershave...Garbage in Garbage out...
your denying this GIGO reference to NASA ??
Monday morning quarterbacks .. a Dime a ton.
Guys that experiment outside the Box
PRICELESS.
Thanks Grandma
MarkE
Quote from: ramset on April 30, 2015, 03:11:12 PM
Mark E
Monday morning quarter backs .. a Dime a ton.
Got actual data taken in a vacuum there Chet?
ramset
why don't you put your NASA Jersey on and go show those GIGO boys at NASA
How its Done MarkiE....??
so to be clear your previous statement was disingenuous .
where you said I was fetching and making stuff up??
that is... your GIGO reference to NASA??
Thanks Grandma
MarkE
Quote from: ramset on April 30, 2015, 03:19:06 PM
How its Done Marky....??
NASA alreaady acknowledged that the tests they did without pumping down a vacuum were worthless.
No you are the person who is making up things I have not said.  It's pretty sad.
