R-Walker Selfsustaining Free Energy bike from Mexico
Started by hartiberlin, May 11, 2015, 02:29:11 PM
ALVARO_CS
Google lost in translation  :P . Here my version:
Yes it is all right. You can post the information ..
Well, on a single charge the bike can move at 30 kilometers per hour with a maximum weight of 100 kilograms on it .
Yes it has a special system for energy generation. It produces 18 volts at 2 A. But when passing through the storage tanks, it rises to 42 volts and 1500 wats.
Yes,  also the engine BackEMF is used so that the motor works as a generator as well.
hope this helps
cheers
hartiberlin
New Answer from Victor:
Gracias por los buenos deseos. Asi es sigo en rumania, mañana es la premiacion del concurso infomatrix. El dia martes regreso a mexico. Claro que esa tecnologia esta diseñada para los pobres para ayudar a la humanidad. Y dejar. A un lado los pensamientos elitistas que bloquean el acceso a personas de bajos recursos a la tecnologia.. Por ahora no puedo publicar ningun diagramas. Sera en unos meses cuando ya se de libremente esta en prosceso de patente. Ahora.
Si es un viejo motor con escobillas de grafito. Se tiene un generador de alto impacto de campos magneticos
Google translation:
Thanks for the good wishes . So it is still in Romania , tomorrow the awards ceremony of the contest Infomatrix .
On Tuesday back to mexico . Clearly, this technology is designed for the poor to help humanity. And leave .
On one side the elitist thoughts that block access to low- technology resources ..
For now I can not post any diagrams.
It will be in a few months when he was already in prosceso freely this patent . Now .
If it is an old motor with graphite brushes . It has a high impact generator of magnetic fields
hartiberlin
Further info:
Prefiero trabajar con frecuencias continuas estables. Los picos pueden dañar la regeneracion electrica.
I prefer to work with stable continuous frequencies. The peaks can damage the electrical regeneration.
hartiberlin
I asked:
I see.
But how do you convert 36 Watts  into 1500 Watts ?
Do you have modified the motor ?
Do you use additional magnets and coils inside it ?
Answer:
En difinitiva se tiene que alterar los campos magneticos
In difinitiva it has to alter the magnetic fields
Probably it means, one must definaltely change the magnetic fields...
hartiberlin
I asked:
I see.
so you changed the whole motor configuration with all its internal coils and
magnets ?
Answer:
Asi es.
Se modifico el motor.
So it is.
The engine was modified.
