R-Walker Selfsustaining Free Energy bike from Mexico
Started by hartiberlin, May 11, 2015, 02:29:11 PM
hartiberlin
Next question from me was:
Do you convert the 12 Volts from the battery to 42 Volts and then you energize ( pulse)  the motor coils with this 42 Volts ? And the BackEMF is then stored in the Super Capacitors ?
Answer:
Es el mismo calibre de cable..el convertidor solo es para disminuir el voltaje para no quemar los componentes.
It's the same caliber cable..el converter is only to decrease the voltage to avoid burning components.
MarkE
Quote from: hartiberlin on May 17, 2015, 03:49:36 PM
I asked:
I see.
so you changed the whole motor configuration with all its internal coils and
magnets ?
Answer:
Asi es.
Se modifico el motor.
So it is.
The engine was modified.
Given the language barriers and also the high possiblity that there is misunderstanding on the part of the teens who built this bike, I suggest that you ask:
1) What are the battery ratings:  Voltage and amp hours or Watt hours.
2) What specific tests were performed to determine the bike's capabilities:  How far did the bike go, and was that over a closed circuit, and what was the terrain, and with how heavy a rider before the battery needed to be recharged.
hartiberlin
I asked:
But you said, you used 42 volts to drive the motor?
So did you increase the Voltage ?
answer:
Asi es se aumenta la tension del motor. Pero me refiero a la disminucion de voltaje de algunos componentes.
Que estan previos a la generacion de energia
So is the motor voltage is increased. But I mean the voltage decrease of some components.
They are before power generation
MarkE
Quote from: hartiberlin on May 17, 2015, 04:16:30 PM
I asked:
answer:
Stefan this sounds like they use a buck converter to generate low voltage for logic, say if they have an Arduino or some other microcontroller board running off 5V or 3.3V, and a boost converter to run the electric motor.
cheors
the motor modification has something to do with ufopolitics's assymetry concept ?
