The bearing motor
Started by tinman, May 28, 2015, 11:10:41 PM
Magluvin
Quote from: tinman on June 08, 2015, 07:19:18 PM
No current will be produced by moving the stator wires or brushes through the field,as both  the negative and positive side of the wires/brushes are moving together through the same field at the same time,and thus the net result would be zero.
I like this setup where he has counter rotating disc.
https://www.youtube.com/watch?v=aKr8ub5ZXls
If so, then that would indicate a charge already set up in the disk??? Could we just put a bunch of connections around the disk and just switch from one to the next and pull current??? Hmm, I think we are misinterpreting some things possibly.
Not sure I understand that vid.  Are the disks on the same side of the magnet? Why do they counter rotate? Is one disk reacting off of the other to counter rotate?
Why is my post reply box 8 feet long???
I get more and more feelings of wondering if the site is going to work for me today, every day.  Almost every day the site is either down at some point or something is going on. And if its backup of the site, there is no message of doing so like there used to be.  Even when I check the site on my cell phone, this site will shut down my phone browser. but no other sites do that. None of them.
Mags
gravityblock
Quote from: Magluvin on June 08, 2015, 08:52:02 PM
Mags
Mags,
Both disks are on the same side of the magnet.  The force is in the same direction for both disks, however they counter rotate because the forces are on different sides of the center of rotation.  The force is on the left side of the top disk and on the right side of the bottom disk, thus a counter rotation.  There is no force on the right side of the top disk and no force on the left side of the bottom disk.
Gravock
tinman
Quote from: gravityblock on June 08, 2015, 10:10:59 PM
Mags,
Gravock
No
It dosnt matter what side of the disc the wires are on, the force will still be in the same direction as we are dealing with circles.
The disc spin in opposite directions because one wire is the positive, and the other wire is the negative-the current flows are in different directions, an thus so is the rotations.
Magluvin
Quote from: tinman on June 09, 2015, 12:23:26 AM
No
Yeah, I understand that the wire can contact the disk anywhere on the outer perimeter to get the same results.
And now I understand that one disk has current running opposite of the other. ;)
Mags
gravityblock
No
LOL.
Gravock
