Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
Ufopolitics
Hello,
I am sorry, but this guy, Mario Gudec, (see video below) has it all wrong  on his 3D CAD setup about Lüling...
https://www.youtube.com/watch?v=BmGx_XQTOHw
His Stator Magnets are mounted on springs??
He adds an electric "Motor" in his little yellow box, which supposedly spins the whole shaft?
All of the above is WRONG!!
His Magnetic Polarizations are also wrong...
He does not even mention the word NEUTRALIZATION...and that is the basic knowledge required to understand Lüling Motor.
Plus, I will repeat myself AGAIN!!...Lüling does NOT uses any Electrical Motors nor coils to achieve rotation on ANY of his Motors.
The only electrical coils Lüling uses are the two Air Valve Solenoids in the front of Motor, at right and left upper ends.
Come on Guys...just because He shows some nice 3D Colored CAD's...that is enough to convince You?
Has He done any REAL BUILT PROTOTYPE, to back up his claims?
Absolutely Zero, NONE!!...But, People believe his drawings are correct...hahahahaha
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
synchro1
Quote from: Ufopolitics on September 14, 2021, 10:06:17 AM
Hello,
Cheers
Ufopolitics
@Ufopolitics,
Let's say the drawing's correct. Would the Cams work together or would they alternate?
Ufopolitics
Quote from: synchro1 on September 14, 2021, 10:38:59 AM
@Ufopolitics,
Hello Synchro1,
The "cams" as you call them...and Gudec shows Four (4) Plus Two on each Stator...are only on the Motor that is NOT running, but the prototype he spins with his fingers...
The Running Motor, and the one I am following, and reproducing, just because it is running, plus seen in more detail...does not have "Magnetic Cams", but instead, they are Transfer Rods for the Angular Mechanic Movements...for the Steel Arc that reciprocates back and forth in the back...and...Both Transferring Shafts are only moved by air pistons and a pivot bracket seen on Right Left upper side, in the front plate.
We can NOT mix both Models!!...as they are different, same principle, but different in Structure
That prototype Luling shows next to him, not running...and that He spins the Rotor and "Cam"...has Two Modules only.
And the Motor that is running, has Four Modules of Rotors and Steel Arc Plates.
That not running motor we all know absolutely nothing...and "theorizing" or "imagine" is all we can do...
While the Running Model...has many different angles of view...PLUS, it is Running!!
P.D: But, still, Gudec Drawing is NOT correct!!
Cheers
―Leonardo da Vinci
Ufopolitics
Quote from: lancaIV on September 14, 2021, 11:06:17 AM
https://translate.google.com/translate?sl=auto&tl=en&u=https://gehtanders.de/friedrich-lueling-magnetmotor/
compared
http://www.rexresearch.com/kenyon/kenyon.htm magnetic force decrease or increase or neutralizing concept
Lueling his 4x4 magnet motor
with
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19720623&CC=FR&NR=2112768A5&KC=A5
only magnetic : a claim
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920423&CC=DE&NR=4033061A1&KC=A1
citing documents : !
btw : https://translate.googleusercontent.com/translate_c?hl=de&sl=auto&tl=en&u=http://gehtanders.de/Downloads/NET0715S26.pdf&usg=ALkJrhhYadwdk5bFh0gONL4HeAJJVOpVzQ
Meanwhile
he think the engine so far
to have perfected that he
him in the UFO newsreel
could imagine for the first time.
Hello,
What is your point?
Neutralization is only utilized as a SWITCH...
1- By Turning Neutralization ON...Magnets in the Rotor, Spin Freely.
2- By Turning Neutralization OFF in JUST ONE of the Two Interactions (Attract or Repulse), it ENHANCES, STRENGHTEN, UNLEASHES the other one.
3- Neutralization goes back ON, In order for rotor Magnets to pass the Sticking Point...or to pass the repulsion Cogging...depending which Interaction You are using to Spin Rotor...Repulse or Attract.
That simple Guys...
Cheers
―Leonardo da Vinci
