Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
synchro1
The magnets in Gudec's drawing can either back up together or retract one at a time. Reducing the repulsion on one side only should cause rotation. Moving them together would result in cancelation. The firing sequence would follow. Alternate retraction might couple with a simultaneous one on the attraction stroke.
Ufopolitics,
description :
The rotation of the magnetic motor is 290 rpm.
During this time, the magnetic force is neutralized 580 times.
It can therefore be assumed that the stator has built in two opposing magnets, the magnetic force of which can be variably neutralized.
1 switch per stator  ? 1 switch for the 4 stators ?
The fifth its function : commutation ? motor-wheel  weight counter-mass ?
1 switch for 4x  90° geometric  balanced pm position = 4 stators x 90° = 360° = 1 rotation from the shaft-wheel
Ufopolitics
Quote from: lancaIV on September 14, 2021, 11:24:07 AM
Ufopolitics,
description :
It is correct, Luling Motor spins at 290 RPM's, and Neutralization switches  by Two Times per RPM, or 580 Times @ 290 RPM.
It simply means that the Rotor has Two Magnets, set at 180º...and also Two Magnets in Stators, also at 180º... per Module, the running Motor has Four Modules.
For Neutralization to take place, you must Unbalance or weaken one of the two magnets in Stator, now, this magnet being used as "The Switch" will NOT spin rotor!! so ONLY one set of Magnets (Rotor-Stator) are actually running Motor...So this "only working magnet" needs to be neutralized Two times per RPM...Understand?
Did You see my Video about this?
Here:
https://www.youtube.com/watch?v=ytCVQ-OZZmM
https://imageshack.com/a/yvsw7/1
Cheers
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics,
my magnet motor research goes more than twenty years back !
other example https://patents.google.com/patent/US3811058A/en  to https://patents.google.com/patent/US4345174A/en
And when You relates such precise constructed motor construction like Lueling his prototypes so we have to calculate with 20 Euros and more
as mass price per Kg ! International average ! G7 : 30 Euros+/Kg !
To get it cheaper the change to pm/em is easier and less mass using !
I only overshowed shortly Your vid,without serious study,but I remark that the evolution steps are more complicated than "outsider" thinks to align the forces/their actions right !
Fix rotation/min or variable : ?  the next question !
Lueling motor output to gear/transmission ?
I am not technology-oriented but per unit output costs calculating !
Target : 1 Euro-cent/KWh by permanent work output ,for the generator-owner the price !
Ufopolitics
IancaIV,
This Lüling Motor research and development is not to start "commercializing it" !!
To me, this Motor is beyond than using it to run a Home Generator...this is beyond searching for applications!!!
This Motor is based on Permanent Magnets on Rotor and Stator...which happens that our World Academy says, magnets have NO ENERGY...
I respect your over 20 years of research into magnetism...
I have been researching plus building magnetic motors, plus Electric Motors from SCRATCH, for also decades...so  what?
I have Patents in  the USPTO...so what?
This Motor could easily be built in Carbon Fibers, and composites fibers, like KEVLAR, Fiberglass...etc,etc...since it runs VERY COLD!!
But you wrote:
QuoteI only overshowed shortly Your vid,without serious study,
So, you do not pay any importance That I have shown a Magnetic Motor that can go FASTER than Luling??!!...400+ RPM's?
I can make a 3600 RPM Motor...based on Luling Tech...that simple...
See the HUGE difference, is that I not only can "research" but I CAN ALSO BUILD REAL MOTORS!!!
Bye
―Leonardo da Vinci
