World's first real Free Energy Flashlight - no shaking - no batteries! No Solar
Started by e2matrix, August 29, 2015, 09:01:12 PM
skywatcher
With permission from Adgex, i'm posting my last email exchange with them, for your information (or entertainment ;) ).
Hello Mr. xxxxxxxxxx!
First of all, I'd like to present our apologies for such unpleasant experience with ELFE flashlight.
We are investigating the problem now and we believe that it is associated with the glueing matter, which were used for sealing the flashlight.
At the end of the last year, we figured out that some of the flashlight had a defect button, and we revoked all batch to rectify the fault.
As per well-grounded recommendation of our supplier, we took a desicion to use a special glue to eliminate the defect we had.
Apparently, using glueing matter have happened to be a chemical substance, which fixed the button problem but at the same isolated and even damaged some contact points, essentially required for seamless charging of the flashlight.
We are deeply dissapointed over the incident, but we will put forth all our exertions to ascertain and subsequently correct the fault.
We are sure about ELFE's capabilities so we will change all faulty flashlights free of charge. No need to send them back, once the defect is rectified, we will ship you new and fully serviceable ELFE.
Should you need any further support, please contact me without hesitation
Best Regards,
Vasily Muzanov
Hello Mr. Muzanov,
thanks for your positive answer.  :)
Although your explanation is not really compatible to my technical knowledge ;) i appreciate your offer to
replace the unit and i will be happy to give it a second try. For the replacement the color is not important
so if you only have certain colors it doesn't matter what color it has.
Your explanation sounds not logical to me, because when the switch is off it should not matter if the contact
is good or not. And it's beyond my comprehension how accumulators should be recharged in an open circuit.
The only possibility i can imagine is that they are recharged by their internal chemistry itself, but then the
contact also should be irrelevant.
So i hope you are really sure that your technology really works, otherwise we could skip the second try and refund the money...
Can i post your email on the overunity forum ?  Maybe it would be also interesting to other users.
Best regards,
xxxxxxxxx
Mr. xxxxxxxxxxx!
We believe that glue has affected some parts of converting module (which grabs environmental energy and converts it into electrical) and/or its contacts with accumulators (where converted energy is stored).
We are still working on investigating the reason of the malfunction.
I will keep you updated on the progress of our work
Feel yourself free to post it at respective websites
Regards,
Vasily Muzanov
gravityblock
Quote from: txt on March 03, 2016, 05:43:22 AM
Coherer won't charge any batteries. You need to power the coherer that it can detect any impulses at all. In other words it consumes energy, it does not harvest it.
Once again, a coherer simply acts as a switch that conducts current in the presence of radio waves.  The coherer doesn't need an external power source other than RF in order to act as a switch for current to flow and to induce tiny vibrations inside the resonant chamber due to the cohering and decohering of the so-called batteries.
Gravock
skywatcher
If we take Mr. Muzanov's infos at face value, we can conclude the following:
a) If the glue has damaged any contacts, there must be more contacts inside the switch as expected, because the normal switch functionality is working well.
b) There must be some 'converter' inside the switch which harvests and converts the energy.
c) This means: there is nothing special about the accumulators.
d) Because charging doesn't work in an open circuit, there must be some sort of circuit inside the switch which switches off the LED but allows current to flow into the accumulators.
    But how can this be possible without lighting the LED ?
That's pretty hard stuff to beleive...  :o
Pirate88179
Good evening and now we return to.....
The Dead Zone.
PS  I think that the only thing being accumulated here is money.
skywatcher
Quote from: Pirate88179 on March 03, 2016, 02:33:12 PM
Money is also some sort of energy, so it's 'free energy'. At least for them.  ;)
