Magnetic mechanical Resonance ideas
Started by dom444, October 12, 2015, 07:40:31 PM
sm0ky2
in a vertical set-up, for the system to achieve a true resonance,...
the size of the magnets must be different, to account for the force of gravity.
a larger magnet below, and smaller above. If the ratio is appropriate, gravity can be completely opposed in the vertical range of motion.
allowing for a purely magnetic response.
for the ease of experiment, I recommend using a horizontal set-up, like the one TK showed in the Piezo video.
When you consider the energy of gravity vs the EM field,... gravity always wins, by just a little... (heat, em radiation etc.)
sm0ky2
also, just a side though.....
it may be useful to consider the frequency vs the range of motion,..
i.e. "wavelength", or something along those lines......
Berto3
The years are counting; my eyesight is becoming bad. That is for a tinkerer, like me, too bad.
Nobody here on this forum is complaining about age and health; but I do. Today I was making
a new coil system for the resonator. It was an effort to see the lines and the copper wires sharp.
This week I tested the EM Resonator intensive with 2 big (generator) pickup coils. They are bifilar
coiled with thin AWG36 wire. One pickup coil is 2 x 320 Ohm 40mH. All windings in series are
producing about 2.5V DC. The shortcut current is some mA. This is not the way to go.
To catch more flux in the coils I had to make a 'real' linear generator coil stack. The coils became
more flat (no pancakes) and the wire thicker AWG32. The stack contains 7 coils with space in-between.
I hope that this single winded small coils, 10 Ohm, 1.5mH each, have a better output.
At least they will better catch the flux from the fast, free flying magnets inside the resonator.
Here some photo's from the coil factory.
Berto3
Last week I was testing the Resonator on output power. The pickup coils are producing not enough energy.
I realized that I had to make new generator coils. This became a stack of seven small coils spread over 6 cm.
Motor and the generator circuits are now on separated breadboards. The use of super capacitors improve
the puls power in the motor coil. This you can see and hear in the video when I switch the caps on.
I was very curious what the output power of the coil stack was doing. The first testst were disappointing.
All coils in series arouse lesser power than the single coils in series. I think the coil wire is to thick, AWG32.
https://www.youtube.com/watch?v=n50dPf4PyFc
Berto3
Do Heinrich Kunel's procedures and devices for energy production actually work?
To find out I take a small dodge from the resonator to investigate his motionless generators.
All the materials, electronics and measuring tools are ready to check out his claim for overunity.
His drawings I saw so often, that now the time has come to build and test this energy device.
