verpies
Quote from: gotoluc on December 26, 2015, 11:15:45 PM
In the meantime I've enlarged the pics and added a few notes.
These notes are correct.
I will not elaborate now...still in Xmas mode
synchro1
Hi Brad
thanks for your additional posts and interest.
I'm away for a day but Monday afternoon I'll be back and can further test this.
Luc
@Verpies, Tinman and Milehigh:
Luc has a scope shot above labeled "Reverse direction Flyback". How does this equate with your "Same direction" theory for BEMF?
gotoluc
Quote from: synchro1 on December 27, 2015, 09:00:53 AM
Hi synchro1,
you are still under moderation but I will allow your posts as long as they conform to the rules I wrote in my first post of this topic.
It's true I've suggested a reverse flyback on the bucking E cores but with a question mark.  Let's allow the EE to think about it a little and see what they make of it.
I will be performing the test TinMan has suggested to see what other results come of it.
Kind regards
Luc
verpies
It would be a violation with one coil, but with two coils one can push flux and current into the other coil.
Without seeing two gate waveforms (or d-s) on the same scopeshot, it is difficult to conclude much more.
Loosely coupled inductors ( a transformer with low k coupling coefficient ) are notoriously hard to analyze when they have capacitors across these inductors on both sides.  Without the diodes in series they behave like a tuned transformer.
itsu
I build the below verpies "C2 discharge" version (so with the MOSFET driver), and found the below screenshot signals.
As normal, blue is across CSR (point A to B)
Purple is across the Q1 MOSFET drain (point C to B)
Yellow is across the C2 cap (point D to B).
C2 cap is a 2.2uF one
2e screenshot is a zoomed in one.
Is this the kind of signal you would expect for the yellow one?
Regards Itsu
