Rotating Magnetic Field's and Inductors.
Started by tinman, December 14, 2015, 09:08:53 AM
gotoluc
Quote from: picowatt on January 07, 2016, 10:46:49 AM
Did you perhaps use the same part number/core mentioned in this video that you linked to in a post you made discussing this? (Part number MP1305LF3T)
https://www.youtube.com/watch?v=PuzSkKlnCzc
Taken from:
http://overunity.com/11377/magnet-inductance-boost-with-finemet-nanocrystaline-core/#.Vo6HDFLCvzE
PW
I forgot I started a topic about it. Thanks PW for finding it.
Eric is the one who first brought my attention to this Inductance boost by magnet. However,  I already had the 2 Finemet Toroid for Orbo testing but good chances they may be the same, they look to be about the same size. One way or the other we know his part number works, so I would say that should be good enough.
Eric's test setup is not very refined but proved the point. After my tests I found the ideal magnet size and magnet location to maximize Inductance which was in the toroid center.
Magnet was 1/4 inch N45 Neo cylinder, magnetized top to bottom.
Hope this helps
Luc
gotoluc
I just found this topic as well
http://overunity.com/8892/self-running-coil/msg236731/#msg236731
Looks like Eric is user void109 and had a MP1305LF3T finemet toroid. So he is the one who brought my attention to it in April 2010.
I refined the effect to minimum magnet size and ideal magnet location (toroid center) to maximize Inductance.
Luc
shylo
The field is always there.
It can be negative or positive
It can be captured in both signs.
Use it.
artv
tinman
Hey guy's
just letting you know that i will more than likely be off line for some time.
The south west of our state (where i live) is being devastated by the largest recorded bush fire so far.
The fire has already taken out 1 town,and half of another on it's way toward my area.
Power in some areas has been lost,and it seems that most of the south west is going to loose power for some weeks due to the fires. There is no more fuel available from the service stations,as our corner has been cut off due to both the major highways being closed. Food is also going to be an issue ,due to the fact that no truck can get to this corner of the state ATM.
So were just going to dig in for the long haul,and will be back as soon as everything returns back to normal around here.
https://www.youtube.com/watch?v=I6Dv3zHDGgQ
Brad.
Dog-One
Quote from: tinman on January 08, 2016, 06:26:49 AM
Good grief Brad.  Not good news at all.
Hang in there best you can and know your limitations.  When it's time to go, make sure you have time to go.  Get everything packed up sooner rather than later.
I'll keep my fingers crossed for you, hoping this blaze turns itself off.
