Thanks to ALL for your help!!
Stan Meyer's Initial Technology Replicated
Started by chessnyt, January 10, 2016, 06:41:51 PM
chessnyt
Quote from: SoManyWires on February 16, 2016, 01:04:34 PM
Bernie will win based on there being no competition due to your not running.
I would have considered running, but they said I couldn't use the Oval Office for conducting experiments  ::)
memoryman
Nonsense; the Oval Office is continuously used to conduct experiments, mainly social.
Bob Smith
@Chessnyt
Glad you picked up on that EPD quote. It got smothered pretty quick when I put it up - no surprise there.  Here's another one from a man named John Myatt, who is a NZ Maori, I believe. He claims he was there when Meyer went to NZ and gave the Maoris his technology. Here's his explanation with a few extra bits removed:
The key to the Stanley Meyer fuel cell lies in the "Tesla Choke" that uses "Tesla's Regenerative Effect" to effectively recycle charge by recycling the Back EMF of each + pulse to add to the next + pulse. This regenerative effect in resonance essentially cascades the input charges to 1000's of volts greater than what you actually input into the water capacitor.​
I use a Torroidal Core 1.50 inch in diameter, 0.25 inch thick, 200 turns of 24 gauge wire, 600 turns of 36 gauge wire with a blocking diode to isolate the impulses. I feed this torroid with a rectified 260 Volt Variac transformer switched using a circuit and only use about 110 Volts of this. I use a Stanley Meyer Capacitance calculator (WFC v1.0) and then use an online Tesla Inductance and Capacitance equations calculator to determine the resonant frequency of my fuel cells.
The 1 amp is restricted on the Tesla Choke, consumed by a light bulb before entering the Fuel cell and lastly is annihilated within the fuel cell itself because the input signal is 180 degree's out of phase in resonance. What your left with is PURE + & - charge without the magnetic (Amperage) stream. This pure charge without amperage is what rips apart the molecular structure of water gravitationally into its Hydrogen and Oxygen components.
The method of operation of a Fuel Cell is similar to Tesla's anti-gravity field theory that uses an EM gravitational field transmitted 180 degree's out of phase with the Earth's gravitational field creating a Standing-Wave that cancels out the effects of Earths-gravity on the craft allowing the craft to be magnetically repelled from the Earths magnetic field. In the case of a Fuel Cell the covalent bond that binds matter together is cancelled out within the fuel cell by using a resonant signal 180 degree's out of phase which simply switches off this covalent connection allowing the attraction of Pure + & - Charge without its magnetic-(current) losses to rip apart the water.
To cancel out:
Magnetism- the Hot electricity with its magnetic component passes itself at a 90 degree angle leaving only (Cold) pure charge without its radiating magnetic field component. Cold Electricity is also known as negative resistance.
Covalent Bond of matter- a pure charge Cold resonant signal is transmitted 180 degree's out of phase so that the signal passes each other at a 90 degree angle, pure charge can then rip apart matter into its elements.​
Gravity- the EM gravity field with its hot magnetic component is transmitted 180 degree's out of phase with the earths gravity field so that the signal passes each other at a 90 angle leaving the magnetic field of the craft to be repelled just like a magnet from the earths own magnetic field.
I haven't upped the voltage in this demo because I know people will just kiss my ass to no end. This video only demo's negative resistance to show that it is possible to have a amperage restricted reaction... I don't give a Poo if anyone understands this simple tech.
The HOT magnetic component of electricity is what enslaves mankind. The only reason we have the magnetic component in our electricity grid is because it can be measured as it radiates a magnetic field. This radiated field is measured and this is how the power companies bill us. When you buy electricity you're actually paying for is its magnetic field losses to surrounding space- this was designed into the system more than 100 years ago so that our energy expenditure can be metered. There is a secondary function of radiating a magnetic field in that as we consume power we are radiating more losses to surrounding space, so we have to buy more power. For example the Pentium chip in your computer, as this heats up it actually becomes less efficient and consumes more electricity as it radiates more losses in the form of heat to surrounding space.
John Myatt
Source:  http://open-source-energy.org/?topic=1153.0
All the best,
Bob
Bob Smith
Here's another post by the same person, I think (J Myatt) from a YT video which has since been removed (surprise, surprise):
QuotePublished on Jun 4, 2013
  The WFC v1.0 software is Stanley Meyer's original software given to the Maori's in New Zealand from when Meyer went to NZ to share his technology. I used to give this software away on the net and teach people how to calculate and dial into resonance.
You can make your own Tesla Choke using a 20mm cardboard tube. You just wind 2X 190 turns of 5/10mm (Magnet Wire #24). The polarity of L1, L2 is very important as L1 must cancel out the Flux of L2.
There's a picture in one of the slides on Stanley Meyer's Denver presentation that I'd uploaded in my video's.
Tesla Choke
• At LC resonance the positive pulse goes through blocking diode to the positive Tesla Choke.
• Positive pulse hits one side of the bifilar Tesla Choke coils.
• The Tesla Choke coil becomes NORTH charged at the end the diode is attached.
• The positive pulse hits the positive outside tube.
• The positive pulse hits the water.
• The positive pulse potential hits the negative inside tube.
• The positive pulse potential hits the other Tesla Choke coil wire connected to the negative tube making that end NORTH.
Both Choke coils are wrapped the SAME way on a ferrite core. Stanley Meyer's diagrams clearly show that the positive choke has NORTH at the diode end of the positive Tesla Choke and the negative choke has NORTH at the Tesla Chokes opposite end.
The most important aspect is that these fields with NORTH at each end of each of the Tesla Choke coils are that they are in polar opposition to one another, thus restricting current flow to the fuel cell. The Tesla Choke both restricts magnetics (current) to the cells and cascades back-EMF voltage spikes to very high potentials. Also the blocking diode prevents any reversals of current flow which prevents arcing from taking place within the cell. The system is actually series-resonant, so the output voltage is limited only by the Q of the system (by the resistance of the wires in the resonator coil).
Another way is we could just use Tesla patent 593 138 to transmit power and step the voltage up at the transmitter end, then step it back down at the receiver end. Rather than using only a step-down transformer in the receiver, instead we use a hi-Q resonator, and we allow the resonant voltage to rise to a very high value. As a result of this, massive amounts of EM energy will be "sucked" into the receiver and use this energy to power our HHO cells or sell power to the power grid.
Here's where I posted it:  http://overunity.com/6763/energy-amplification/msg410388/#msg410388
Bob
SeaMonkey
Bob Smith,
It rather looks like the purpose of the circuit is to provide
the two plates of the WFC with the same polarity of potential
at a very high voltage.  This would set up between the plates
a strong field of electrical repulsion rather than attraction
as would be the case when the plates are of opposite polarity.
The result would be very little current flow, if any, between the
plates.
What are your thoughts on the quote from J. Myatt?
