Is the free energy gamechanger here ? 2000 Watts u-plug generator
Started by hartiberlin, February 04, 2016, 11:21:58 PM
Look at the inconsistencies in their story.
1. They claim that the magnets + geartrain weigh 7 pounds. This alone is not plausible, for magnets of the strength claimed.
2. They claim to have had the device tested at JPL, under the supervision of NASA and DHS. Yet the "US Government" only ordered a couple of units, rather than immediately giving them a big contract, or inviting them for "tea, no biscuits" like some other people have been invited   ;)   . And their YT video is still up.....
3. They claim to have patents, but a patent search using Google advanced patent search doesn't come up with any patents in the name of the claimant.
4. They claim to be making 50 units a week, since two months ago at least. Yet nobody has one to test, and the "US Government" is still waiting on the couple of units they allegedly ordered.
5. No news on Fox or CNN about this miracle device.
None of this is proof that they don't have what they claim, of course. But come on ... if you showed YOUR government a self running magnet motor coupled to a generator that could power 2 kW of load, without any input, two years ago... what do you think would happen to _you_ by now? Would you still be trying to raise money by crowdfunding, and posting YT videos to try to drum up sales? I don't think so... and neither do you, I'll bet.
By the way, Ed Mitchell died yesterday, may he rest in peace. So that's one less moon-walker for you to worry about.
tinman
Quote from: Dog-One on February 05, 2016, 08:59:59 PM
Maybe this whole U-Plug thing is just a hint, not an actual product.
Brad, you're good with mechanical devices.  Tim mentions a simplified planetary gear.  I'm thinking simplified means removal of the sun gear.  So lets say we have two identical ends, shafts connecting the planetary gears on each side, brackets on each side to keep the planetary gears locked into the ring gear and the tube connecting the ring gears.  On the shafts we mount magnets.  The rotating magnets on the shafts are timed via the planetary gears and the ring gear.  The idea here is the ring gear forces the direction of rotation.  So suppose the magnets on the shaft are aligned via the gear teeth to always repel each other--we will call one magnet the pusher and the other magnet the pushie, in respect of their direction of rotation around the ring gear.  The pusher magnet's vector force is "into" the ring gear, so it doesn't really want to back up.  The pushie magnet's vector force is pretty much inline with the curvature of the ring gear, so it freely moves forward.
Let's suppose we have six shafts each with magnets and a planetary gear on each end so the proximity of the magnets is fairly close together.  The brackets on each end preserve the spacing and the ring gear is of appropriate size to fit all this in without the planetary gears hitting or magnets physically touching each other.  The magnets themselves could be cylinder magnets with a hole bored through them for the shaft and radially magnetized.  There is probably a critical relationship between the diameter of these magnets and the diameter of the planetary gears.
What I picture in my mind is something similar to a continuous loop of falling dominoes.  Because of the gears, they are constantly reset.  Instead of falling linearly, they fall radially.
I don't know if any of this rambling makes any sense to anyone.  I don't have the mechanical abilities to assemble a prototype, though I could probably design the basics of it in CAD, maybe even animate it with enough practice.  Just tossing the thought out there that this U-Plug isn't the Holy Grail but there could be an idea embedded in all the hogwash that is.  Maybe it's a clue how to actually design a magnet motor.  I'd like to know if someone that understands what I'm saying has the mechanical wherewithal to actually find out.
I seem to remember another magnet motor being made many years ago,that was based around a planetary arrangement--back in the 50's i think. Was claimed to be a self runner,but of course no one has a working model-AFAIK.
I would think the pinion gear is kept,and the planetary gears are what have the shafts that the magnets are fixed to. The hub gear(or crown wheel) would be emitted. The planetary gears would no longer orbit the pinion,but would be held into position by the idler plate/carrier plate. You now have a triangle pattern of rotating cylinder magnets that are magnetized diametrically,and this would create some very sharp pole flipping fields at the center of the 3 rotating magnets.
There are many things left to be discovered,and no one on this forum can say for sure whether or not for certainty that the next device is not one of them new discoveries simply by looking at a video,or reading some text. They are taking a !!best guess!!,a guess where the odds are in there favor--nothing more. Only after careful research and testing ,can a final call be made.
I once designed a gear box where the input shaft could turn in either direction,but the output shaft would always turn in only one direction-no dog clutches or shifting gears--every gear constantly meshed,and never moved position. There was no gear changing shifter,and the output shaft always had unidirectional torque-regardless of the direction of the applied input torque,and there was no torque lag time between the input and output shafts. Never did find a use for such a gear box,but who know's,one day it may come about.
Brad
DreamThinkBuild
Hi DogOne,
There are many patent claims that have a similar planetary gear type magnet motor structure. You can see some here.
https://patents.google.com/?q=magnetic+motor&q=planetary,gear&q=H02K53%2f00
The new google patent search allows you to search by CPC codes to narrow down what your looking for.
They do update the codes so you may have to check here for changes.
http://www.cooperativepatentclassification.org/index.html
http://www.cooperativepatentclassification.org/cpcSchemeAndDefinitions/table.html
It's a little overwhelming the best way to find codes is by searching for in the patents then looking at the classification codes that are related.
An older site which the codes may be outdated but gives you an easier to see relationship of the classifications is:
http://www.google.com/patents/sitemap/en/Sitemap.html
There are so many patents that have claims, a lot can be dismissed as just bad or some that don't have enough information or purposely left out.
tinman
author=TinselKoala link=topic=16390.msg473304#msg473304 date=1454740332]
Quote1. They claim that the magnets + geartrain weigh 7 pounds. This alone is not plausible, for magnets of the strength claimed.
Titanium is pretty light. Maybe the gears are made from that.
And who is to say the pull force of the magnet is measured from only one side of the magnet,when in a rotating situation,where both ends of the magnet provide that pull force at the same time.
If one end of the magnet has a pull force of 100lb's,then the other end of the magnet will also provide 100lb's of pull force as well.
Quote2. They claim to have had the device tested at JPL, under the supervision of NASA and DHS. Yet the "US Government" only ordered a couple of units, rather than immediately giving them a big contract, or inviting them for "tea, no biscuits" like some other people have been invited   ;)   . And their YT video is still up.....
Would the US government need any more than two unit's to have either the armed forces or NASA replicate it?. Why would you think they need more than this to achieve a working replication?. I wonder if there patent will now be approved by the said government that just bought two unit's,or will it now be declined--some national security bullshit again :D
Cake and soft drink is a far better option when it's hot ;),and a video that shows a piece of PVC pipe with wires coming out of it dose not give away to much i wouldnt think ;)
Quote5. No news on Fox or CNN about this miracle device
Like you'd ever see any real or interesting news on those channels lol.
QuoteNone of this is proof that they don't have what they claim, of course. But come on ... if you showed YOUR government a self running magnet motor coupled to a generator that could power 2 kW of load, without any input, two years ago... what do you think would happen to _you_ by now? Would you still be trying to raise money by crowdfunding, and posting YT videos to try to drum up sales? I don't think so... and neither do you, I'll bet.
Hell no.
I'd either be
1-dead
2-kicking back in the Bahamas
3-Doing what i could without stirring up the ants nest-so to speak.
QuoteBy the way, Ed Mitchell died yesterday, may he rest in peace. So that's one less moon-walker for you to worry about.
Sorry to hear that.
One of my best friends died of cancer last wednesday--never smoked a ciggy in his life. He was more real to me than any moon walker.
Brad
Dog-One
Quote from: tinman on February 06, 2016, 02:02:38 AM
That is exactly my point.  Maybe Tim knows there is simply no way to move forward, so he elected to throw us a bone without directly "stirring up the ants nest", then took the easy way out.
And I do like your planetary arrangement better than mine.  The more I think about it, I suppose it could be possible to stuff just the needed components in there.  One would have to expect a rough prototype to be much less optimized and quite a bit larger than a finely tuned final product.
We still don't have any sort of background on Tim, so who knows what and who he is connected to, what his skills are or what he is capable of.  If he has any association with JPL or NASA, it's likely he was "advised" as to what his options are.
I'll be very surprised if this U-Plug device sees the light of day.  I'm hopeful, but not real optimistic.  Instead, I think we will have to take what we got up to now and see if there is any way to make something of it.  Bugger.
