HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
r2fpl
Quote from: Sergh on May 31, 2023, 12:49:04 PM
These diodes do not rectify. In principle, they cannot rectify alternating current. The resistance of such a diode in both directions is a couple of ohms. They can only generate microwaves. The efficiency is low. With a constant current of 2 amperes and a voltage of 4 - 5 volts, this is 8 -10 watts of power, we get 0.2 watts at the output. They heat up strongly. These diodes is very small. Difficult to dissipate heat. You need a big radiator or water. Without external airflow, it works for a couple of minutes before overheating. A few burned out or broke due to the high clamping force during the experiments.
The bottom photo shows types of homemade generators.
Microwave 20+ GHz is very strongly absorbed by water. Even a 5 millimeter layer of water reduces everything to zero. No beneficial effect for HHO was observed. The problem is not so easy to solve. I put it away a couple of years ago. Until the essential details are clarified.
To rectify the microwave, other diodes are needed. If you are interested, search the Internet for "microwave harvesting".
Zografos is not an expert in microwave or lying.  He believes that no microwave specialist will watch his video.. facepalm. His microwave equipment is mainly for servicing mobile cellular communications, probably outdated and sold cheaply.
The main problem is - this is random industrial equipment for cell towers, which never matches the frequencies that Zografos refers to.
There was a video where Zografos tears the paper into which the generator is glued, and there you can see 2 ordinary powerful low-frequency transistors in the TO247 package. Is there an induction heater coil in the "Microwave Emitter"?
Here, a man from Greece is doing something similar:https://www.youtube.com/watch?v=r2AcIsQyR5s
He said that the inside of his oscillator was covered with gold. I don't know if it's true but he showed it in the video.
kolbacict
Quote from: nix85 on June 01, 2023, 04:14:23 AM
According to the the young inventor, the generator he has designed is capable of running a motor car for 80 kilometres using only one litre of water, without any danger to life or any impact on the environment.
Why does he need a liter of water?  One hundred grams is enough.
Then it will only be necessary to collect the water obtained at the exit.
And return it to the fuel tank.
kolbacict
Quote from: r2fpl on June 01, 2023, 04:56:06 AM
Well, some industrial waveguides are covered with gold. No wonder.
I heard there were even rhodium platings.  And it was the best plating.
nix85
Quote from: kolbacict on June 01, 2023, 07:41:04 AM
Maybe he could. But you forget not all water is the same. The reason hydrogen releases so much energy is cause it is charged with Vril. Is water just formed after burning of hydrogen charged with Vril is a question. Maybe it needs to stay in the sun for a while to get charged.
hartiberlin
Just Define, what really is Vril..
It is more like an esoteric format...not related to hydrogen production.
But don't  bomb again this thread here, just post it into a new thread, if you want to answer...Thanks.
This thread and topic should stay focussed onto the Zografos discussion.Many thanks for understanding.
Regards, Stefan.
