HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
hartiberlin
Quote from: Sergh on May 31, 2023, 12:49:04 PM
These diodes do not rectify. In principle, they cannot rectify alternating current. The resistance of such a diode in both directions is a couple of ohms. They can only generate microwaves. The efficiency is low. With a constant current of 2 amperes and a voltage of 4 - 5 volts, this is 8 -10 watts of power, we get 0.2 watts at the output. They heat up strongly. These diodes is very small. Difficult to dissipate heat. You need a big radiator or water. Without external airflow, it works for a couple of minutes before overheating. A few burned out or broke due to the high clamping force during the experiments.
The bottom photo shows types of homemade generators.
Microwave 20+ GHz is very strongly absorbed by water. Even a 5 millimeter layer of water reduces everything to zero. No beneficial effect for HHO was observed. The problem is not so easy to solve. I put it away a couple of years ago. Until the essential details are clarified.
To rectify the microwave, other diodes are needed. If you are interested, search the Internet for "microwave harvesting".
Zografos is not an expert in microwave or lying.  He believes that no microwave specialist will watch his video.. facepalm. His microwave equipment is mainly for servicing mobile cellular communications, probably outdated and sold cheaply.
The main problem is - this is random industrial equipment for cell towers, which never matches the frequencies that Zografos refers to.
There was a video where Zografos tears the paper into which the generator is glued, and there you can see 2 ordinary powerful low-frequency transistors in the TO247 package. Is there an induction heater coil in the "Microwave Emitter"?
Here, a man from Greece is doing something similar:https://www.youtube.com/watch?v=r2AcIsQyR5s
Hmm, well maybe I mixed this up after my Stroke..
Well well I just rewatched some of his earlier videos and indeed he had other transistors in there...
So maybe he is using the Gunn diodes only for the production of of the hydrogen und uses other transistors just to rectify theRF energy from the Hydrogen foam he has produced inside the small Toy case, where he powers the 2 Fan motors ?
hartiberlin
How is Zografos rectifying this kind of Hydrogen Foam into DC energy ??
Any Idea ?
Does he use Gunn diodes for it or does he have other rectifiers ??
Where is this Zografos Style Antenna from ? did you build it yourself ??
Many thanks.
Regards, STefan.
hartiberlin
Here in this older video at minute 11:41 you can see some other rectifier transistors or diodes:
https://www.youtube.com/watch?v=PWY8iDiCjUA
nix85
There was no need for separate thread, i don't want to start a water engine thread of my own. I didn't "bomb" the thread. Those are water engines and this is a water engine thread, i shared them so people see how many water engines there are except Zografos, in the past and today. Vril is just another name for universal etheric currents (universal fluid) that make up everything, all forms of energy and 'matter'. There is nothing more important in time-space than vril, one substance, one force. Vril in its highest, original form can never be measured directly but only when resisted and slowed down into gravity/magnetism or some lower energy form. Vril is also units of vitality and lifeforce, one may call it electrons but those units are smaller than electrons. Mainstream knows nothing about these most important forms of energy. So what to you seems esoteric and not related to hydrogen production seems esoteric from a limited perspective only. And it is highly related to everything cause it is everything literally, including hydrogen production. Hydrogen and oxygen are elements essential for life and can be charged up with these finer forms of vital energies. Vitality globules, superfine orders of energy are flooding Earth from space, Reich called it orgone. Water and organic materials trap this energy, metals just pass it on. So question remains if just formed water after burning of hydrogen is charged with vril, can that water be split again right away and that hydrogen burned, or it needs to spend some time to get recharged by these subtle energy forms. I don't know of anyone who used the exhaust water as a fuel right away, just looping it. And that speaks a lot.
Once again Keely claimed 42,800 Hz would vaporize water instantly into energy.
Hollingshead claimed his odic (vril) ray dissocciated water into elements instantly.
And then this airship case....
The Democrat-Herald newspaper, of Albany, Oregon, for August 27, 1973, reportedly told that in 1906, a boy named Herbert DeMott, from Mitchell, South Dakota, allegedly boarded an airship that had landed near his family's well.
The boy claimed: "As I approached it, a door rolled back and I was welcomed inside. Its two occupants sat inside on camp stools." They looked like ordinary human beings and they spoke fluent English, but they would not tell him where they were from.
The boy claimed the outer shell of the craft was filled with helium gas, and "when the lever was moved the magnetism from the Earth was cut off. In this fashion the ship was able to ascend."
He claimed that the occupants took water from the farm's horse trough "for use in manufacturing electricity."
Scalar/non-herzian rays dissociate even solid matter, not to mention water.
hartiberlin
Okay, Nix, then keep this in the other new opened topic.Here we wanna just discuss Zografos for now..
Thanks.Regards, Stefan.
