HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
kolbacict
on his channel in YouTube  Stivep1  there were these videos. Now I don't know.
Sergh
I really don't like such messages. >:(  If he had something to tell, he would have told us that.
kolbacict
Sergh
QuoteElectrolysis of water can pass to the second mode.  The second mode is the same as the first mode, differs in that the electrodes are connected to an electric generator 88 through the dynamo-electric transducer 89, the electrical pulse generator 90, and electrical switches 91 and 93. In this case, an alternating current is converted into direct current.  Electric pulses generator 90 generates electrical pulses on electrodes 64 or 71 and 72, 74, 76, 77, 79, 80, 82, 83, 86, 87 at the rated voltage of the electric current.     Electrolysis of water can take place in the third mode.  The third mode is the same as the first, differs from it in that the electrodes are connected to the generator 88 through a source of AC dynamoelectric generator 89, and electrical switches 91 and 94. In this case, an alternating electric current is converted into direct current, low voltage current is converted to high current voltage in the tens of thousands of volts.
   Electrolysis of water can be operated in the fourth mode.  The fourth mode is the same as the third mode is different from them in that the electrodes 64 or 71, 72, 74, 76, 77, 80, 82, 83, 86, 87 are connected to an AC generator 88 through the dynamo-electric transducer 89, a generator 90 electric pulses and electric switches 91 and 95. When this electric current is converted into direct current, low voltage current into high voltage current in tens of thousands of volts and high-voltage electrical discharges are created by pulses.
  Using the electrical switches 91, 92, 93, 94, 95 or 64 in the electrodes 71, 72, 74, 76, 77, 79, 80, 82, 83, 86, 87 can change the direction of electric current.  When the cathode becomes the anode, the anode becomes the cathode, it allows to automate the electrodes of plaque purification alkali.   electrolysis of water can be carried out at any time.  The battery 63 between the perforated plate electrodes 64 in the electrolyte electrolysis occurs with or without the use of ultrasonic or infrasonic waves passing in the electrolyte layer from the bottom up.
https://patents.google.com/patent/RU2243390C1/en?oq=RU+2243390+C1
kolbacict
Quoteit allows to automate the electrodes of plaque purification alkali.
where does he have lye(alkali) there? At first it was about clean water.
