Extra energy saving green project «Syngas generator & burner 1MW»
Started by gverlab, February 28, 2016, 08:25:20 AM
Johan_1955
Quote from: ramset on March 03, 2016, 12:15:48 PM
Johan
when you posted your Link  I did notice it was the same one you have had for quite some time .[very nice BTW]
now I  see its empty ??
http://www.youtube.com/user/OostromTechnicsSL
or is it just here in NE USA ??
You have such nice things to see there ??
Chet
Hi Chet,
It is funny, because today its back again, no explanation from YT!
This is our 3 YT account, 2 of them lost without .............. , same for LinkedIn!
Not a Fan, but pretty good: https://www.youtube.com/watch?v=Dqn0bm4E9yw
Regards, Johan
Johan_1955
Quote from: gverlab on February 29, 2016, 12:10:56 PM
Hello Johan,
I like to reply to you like prof. Fukai from Jp - All depends of great possibilities of water - the water must be structured and activated different methods.
And if you mix this water with fuel - will see results. I cannot explain where our generator get additional energy, but testing by our laboratory and other independent researchers confirm - the water is the fuel, extra fuel.
Gver
Dear Gver,
Pity you don't react! Being familiair with the principe from Fukai. Thinking how you did construct it: When true how it is looking with the After-Burner, than you are blowing lots of pollution in the atmosphere, the metal activators, not good at all, just like a ChemTrail, also bad for Piston-Engine.
For that reason we did construct a closed fluid Rotary Engine, with a good Exhaust-Filter bringing the particle's back to the fuel, it still should stand at: OverunityResearch.com.
Regards, Johan
gverlab
Quote from: gverlab on February 28, 2016, 08:25:20 AM
Ukrainian public research laboratory of alternative energy GverLab looks for partner (investments, grants) to support our very perspective energy saving green project «Syngas generator & burner 1MW with a mini fuel consumption».
Our achievements :
In 2014 GverLab designed, built and tested prototype syngas generator , a power 250 kilowatts, it produces 0.2 Gcal of heat per hour , a fuel consumption - 6 liters of diesel fuel (waste oil, light fuel) and 6 liters of water. In comparison - a fuel consumption of our generator is 3-4 times less than for any industrial burner same capacity.
In 2015 was designed, built and tested more powerful syngas generator 1000 KW, it produces about 0.8 Gcal of heat per hour , a fuel consumption - 30 liters of diesel fuel (waste oil, light fuel) and 50 liters of water. The saving of a fuel consumption - about 300 %.We have the patent for our generator.
Prospects :
In the second stage in 2016 is planned to upgrade significantly the constructed  generators and to build and test two more powerful and economic models of syngas generators 1 MW and 2 MW with fuel consumption of 20 liters per hour and 70 liters of water with minimal harmful emissions (CO2, NO) into the environment. These generators will allow 4-5 times reduce fuel costs comparatively with industrial devices the same power and significantly increase the amount of generated heat.Our patented technology possible production of heat generators capacity from 250 to 10000 kW.
Technology Overview (from our patent)
Generator-burner «Gver1000» produces and burns the syngas simultaneously. An activated water submitted into the generator , turns to steam, then a steam mix with liquid fuel, next the mixture heats in two cells, passes through a catalyst, next heats to a temperature of about 1000 degrees Celsius and produce syngas. The produced synthesis gas burned, generate an heat for the process chamber of generator and for the different purposes- water heating, air heating, steam production, etc.
A distinctive feature of the generator «Gver1000» is producing high-energy gas mixture (synthestemis gas) consists mainly hydrogen H2 plus carbon monoxide CO and combustion of the mixture at high temperature (1300-1600 ° C) .
Appliance
Our generators produce heat, which can be use for production of steam heating boiler water, drying of agricultural  products, forest products, heat large rooms, greenhouses, for road and repearing work in the cold time and to produce  cheap electricity.
Our main goal - significant reduction of harmful emissions into the environment,  significant energy savings and reduce the cost of thermal energy,  partial substitution of imported energy (gas, electricity). Our slogan - «Safe our planet - stop global warming!»
More details - www.gver.tk
In attachment - the presentation of syngas generator.
Good luck!
gverlab
=Extra energy saving green project «Syngas generator & burner 1MW» - new tests on April 2016=
Ukrainian public research laboratory of alternative energy GverLab glad to inform to you about our new successful testings of our 1 MW Syngas generator & burner 1MW on April 2016. We made some upgrades of our generator - use new nozzles, new fuel (waste oil),  new method of water preparing and other generator modernization. We achieved fine results - the heat power - about 1 Gcal per hour,  a fuel consumption (waste oil) - 22 L/hour  plus 40 L/hour a water. Videos of new April testing of our generator 1000 KW are presented on our youtube account  - https://youtu.be/oPMjDOLjeQQ  and https://youtu.be/eKiekKNu3IQ  For comparison - the video of our generator testing in the end of 2015, we used diesel fuel - https://www.youtube.com/watch?v=aBUyHcWHWJU.
In our plans for May 2016 - to use other more effective nozzles, other fuel .All the work we fund ourselves.
History brief reminder:
Our achievements :
On the second stage is planned to build and test  more powerful and economic models of heat generators 1 MW  with fuel consumption 20 liters and 70-100 liters of water per hour with minimal harmful emissions (CO2, NO) into the environment. These generators will allow 3-4 times reduce fuel costs compared with standard devices, and significantly increase the amount of generated heat. On the second stage is planned to build and test  more powerful and economic models of heat generators 1 MW  with fuel consumption 20 liters and 70-100 liters of water per hour with minimal harmful emissions (CO2, NO) into the environment. These generators will allow 3-4 times reduce fuel costs compared with standard devices, and significantly increase the amount of generated heat. We have the patent for our generator. Appliance:
Our generators (from 100 Kw to 10 MW power) produce heat, which can be use for production of steam heating boiler water, drying of agricultural products and wood, heat large rooms, spaces and greenhouses, for road and repearing work in the cold time , for a producing of cheap electricity, as well as for seawater desalination..
We welcome any suggestions for mutually beneficial cooperation or advices, maybe investments.
In attachments- pictures of testing on 18 and 23 April 2016
Pirate88179
Why did you start multiple topics (3) for this same deice?
This is very wasteful and annoying.
This is looking more and more like spam.
