Anyone tried replicating the easy LENR video below?
Started by pomodoro, March 12, 2016, 06:19:07 AM
pomodoro
There is a pretty good video on the playlist of OU.com currently. Looks very simple to replicate. The water temp apparently rises more than it should. Anyone know of replications that either worked or failed? Seems like all you need is a tungsten welding rod, lye, water, thermometer, multimeter, 80v, and an insulated cup
ramset
Have you been able to find the original Link to the Vid ?
it would be good to read his questions and answers too ?
Thx
Chet
Thanks Grandma
pomodoro
Quote from: ramset on March 12, 2016, 07:32:49 AM
Thx
Chet
I can't with my phone.
[size=78%]I'd like to replicate this with my equipment. I can do a full element scan of  the tungsten and solution down to ppm levels. Apparently some transmutation occurs as well. [/size]
ramset
I have looked a bit prior to asking you . some of us have played here with small results.
would be a good experiment to check ,however it would be good to read a bit more of the back and forth
conversations on the original Vid.
and even try some other things in the soup ![yes transmutation would be good to check ...also Peter [ae]
at OUR has some thoughts on welding Rods and transmutation you should touch base with him for some other suggestions ?
have you heard back from the lab on your other thing yet ?
Thanks Grandma
pomodoro
