New April 2016 Video from Kapanadze shows again KWatts of Free Energy
Started by hartiberlin, April 01, 2016, 06:06:31 PM
Hoppy
Quote from: Zeitmaschine on April 22, 2016, 08:15:16 AM
He has done so already. He has all device peripheries moved from their initial positions and earth wires disconnected for close-up inspection in the green box video. Just remaining the far-fetched possibility that the earth wire is secretly stitched together of two different types of wires (none of the spectators became aware of) in order to connect a hidden hot wire.
But not with his latest 2016 video, which is what is under discussion, or with the Aqua2 earth - video evidence for disconnection of braided earth. Its not a far fetched possibly that the green box device cables were 'stitched', its more than likely IMO.
You are showing a power supply into the frequency doubler. What type of power supply is this?
Zeitmaschine
All TK videos are under discussion. And mixing it up with Stepanov videos shall be no mistake too.
The definition of »far-fetched« and »likely«:
Bury a hot wire under the lawn. Attach an invisible connector to its end. Also attach a connector to the bearded man's sole of his shoe. Route a hot wire through his trouser leg and through his shirtsleeve. Connect this hot wire to the device by means of a fake piece of ground wire. Use a piece of ground wire that is multipolar in contrast to the unipolar ground wire connected to the faucet without looking different.
And of course, muzzle that weird wired man.
AC sine wave, I guess?
Hoppy
Zeitmaschine
Kapanadze 2004 device = Stepanov cardboard box device
In each case frequency is 50Hz via sine inverter and 12V car battery. As we can see below, both devices are build upon the same components, but slightly different in design. Stepanov's transformer is hidden behind the big diodes, Kapanadze's transformer is hidden in the Sadolin tin can. Stepanov uses four big diodes, Kapanadze uses four small ones. Stepanov connects two small capacitors together, Kapanadze runs his device with one big capacitor. Stepanov shows us a power resistor on a heat sink, Kapanadze shows us two components on two heat sinks most likely working as resistor(s).
Problem remaining: How to connect those hidden transformers to those visible frequency doublers the right way?
Hoppy
Quote from: Zeitmaschine on April 22, 2016, 12:15:29 PM
Indeed! The fundamental problem: How to loop-back, so the battery and inverter can be removed as we see in Kapanadze's green box video.
