New April 2016 Video from Kapanadze shows again KWatts of Free Energy
Started by hartiberlin, April 01, 2016, 06:06:31 PM
Zeitmaschine
Quote from: forest on May 01, 2016, 06:54:15 AM
Sure, Russian. And device resembles Akula small devices.
Also with hidden battery in the transformer?
Quote from: TinselKoala on May 01, 2016, 05:06:44 AM
Typically, a component will conveniently fail, ending the demonstration, and no spare parts are available -- until after the observers have had to catch their flights home.
End of the demonstration due to a failing component? Surely the investor won't be amused.
Hoppy
Quote from: Zeitmaschine on May 01, 2016, 09:25:46 AM
In Kapanadze's case, the investor is kept well away from the source of power - the generator, so any failure is down to environmental conditions, which are of course outside the control of the operator. For example, in the case of the green box device, a dodgy earth wire, not sucking up enough current, or a stormy atmosphere in the case of the Aqua2 device.
FatBird
FatBird
Diagram from Kapanadze's Patent WO 2008/103130 A1
file:///C:/a/0%20%20%20Misc/0%20%20%20Energy/Kapanadze/Patent%202.htm
My hunch is that where it says Freq Gen, is really a Spark Gap which will generate a Frequency & a LOT of harmonics.
For the input, an inexpensive Neon Sign HV transformer should work OR possibly a Microwave Oven Xfmr?
It's HV output can probably jump across a car spark plug gap.
The Voltage has to be high enough to jump the Spark Gap & energize Primary Coil 1.
The Diagram From The Web (bottom photo) shows a Spark Gap.
It looks like he uses an automotive Spark Plug for a Spark Gap in some of his videos.
Just to prove things out, I believe we can temporarily LEAVE OUT parts 6, 9, 10, 11, 12.
Zeitmaschine
QuoteMy hunch is that where it says Freq Gen, is really a Spark Gap which will generate a Frequency & a LOT of harmonics.
My intuition rather says that »Freq Gen« could mean Frequency Doubler. Of course in the patent it would have been too obvious to write it in such a plain way.
»In the Century article Tesla compares extracting energy from the environment to the work of other scientists who were, at that time, learning to condense atmospheric gases into liquids. In particular he cited the work of a Dr. Karl Linde who had discovered what Tesla described as a "self-cooling" method for liquefying air. As Tesla said, "This was the only experimental proof which I was still wanting that energy was obtainable from the medium in the manner contemplated by me.« Tesla's Fuelless Generator
Now we can compare the block diagram below with Linde's self-cooling method and with Kapanadze's patent drawing above. Can we recognize any similarities?
The frequency doubler works like an AC valve. The energy can only flow from 50Hz input to the 100Hz output but not vice versa. On the other hand mixing 100Hz with 50Hz should result in an energy flow from high to low frequency. Hence what could happen if by any chance the grounding of the high voltage between the two transformers supplies that loop with a little bit of additional energy during each oscillation cycle?
Regards ;D
