MetaQEG- An invitation to TinselKoala to a cooperative build.
Started by Meta, April 03, 2016, 12:09:51 AM
verpies
Quote from: massive on April 09, 2016, 04:43:07 AM
is anyone familiar with Ford model T coils or induction coils ?   (alot of people are oblivious)
"Yes", to the latter, "no" to the former.
electrons travel the conductive path of the primary coil , the iron core becomes energized , the reed switch is pulled opened, there by breaking the flow of the electrons
The current might be interrupted in the primary winding, but the electric current keeps flowing in the secondary winding, ...which takes over the flow.
If the secondary winding did not exist, it would be impossible to suddenly interrupt the current in the primary winding.
so .....are electrons capable of switching ?
being switched or switching something else? What?
Meta
- But one could prove that Bearden's MEG works indeed by demonstrating a working MEG. Of course the demonstration must be clear and measurements must be verifiable by third parties.
Said in even simpler terms: The burden of proof is with Bearden or Meta.
Greetings, Conrad
_____________________________________________________
Said is even more simple and repetitive terms.....
I don't have any measuring equipment nor the adaquate apartment in which to conduct a build or measurements. So your presumptions are all wrong. Read the offer again, numbskull.
Meta
Quote from: verpies on April 08, 2016, 11:05:23 AM
Unfortunately esoterics alone, rarely leads to real working devices.  Take the sub ns SPDT HV switch for example.
Fortunately Im using both sides of my brain with intuition and reasoning.
The switching time of 4-30 nanoseconds is going to be hard to reach....however if you search Bearden's Patent on the MEG, which claims overunity, you'll find another cycling interval that is much slower than nanoseconds. In his literature he also speaks of 1m, whatever that is, and also a frequency in the MHz range. Remember, upper partial harmonics can reach to the nanosecond ranges.
massive
the secondary coil is not attached to the primary coil , that is a description of an ignition coil .
the pri is low L , these is high L .  and again , more electron flow .
A rheotome is not magnetic , it is a rotary make and break for DC , = it IS possible for a single coil or dual. its been possible since the 1800s
the effects of electrons , are switching the flow of electrons , using a magnetic reed , sudden make and break generates HV spikes , a quench capacitor is used to store and also to protect the tungsten contantacts from melting
no transistors or timing formulas involved , the switching is governed by the electrons .
@ META you do not need TK or Theoria to build anything , they dont need anyone to build anything .
reading 40 thousand books equates to nothing if you have no practical skills
DO something !
Meta
DO something !
I see you have no sense of Law or justice.....my WILL is to let those that have measuring instruments, do it, but you, who have no skin in the game and no standing with me, interfere with my WILL and contract with others....mind your own business, no one asked you for your intrusions. Is that clear enough?
