real free energy with capacitors thru inductance
Started by jimbo, May 06, 2016, 12:10:35 PM
FatBird
Even a hand drawn schematic or drawing can help us to understand it.
Feel free to use this procedure to post it:
1.  Make a drawing & save it on your PC.
2.  Log in here on this thread & click on Reply.
3.  Click on CHOOSE FILE.
4.  Click on the Links to your drawing on your PC.
5.  Click on POST & it will get UPLOADED right here on this thread.
Thank you.
PolaczekCebulaczek
its not free energy,the circut is complete,the loop closes  through the air- from earth "plate"to negative inverter wire, its virtual HV capacitor/electric field/displacment current.
Magluvin
Quote from: jimbo on May 06, 2016, 12:10:35 PM
As far as free energy is concerned I've found it. And it was so in my face the hole time. Here I go again! When you look at the formula for a set of caps in series each one is a reciprocal of the total every were you look on the net you get that answer and it's true as far as they go .what they didn't tell you was that the capacity is spread out being that the plates are spread out .the total is equal to the original single cap so they say that there's no real advantage that is if they are all the same uf. To start with .what's not said is by spreading out the charge you increase the inductance side of the charge and reduce the conductive side .with 5 caps is a series the first plate is charged by conductance the rest by inductance aka free. The string is under strain by the first positive plate and has to   regauge. It's potential to match the first plates level and there by balance every thing out . the energy to do this is pulled from the earth .you can put a amp meter in line with the ground and see it working. Then when the string settles down the caps can be fired off and evey thing started again and again and again. I've done this .with a inverter a bridge rectifier  and two big caps 60 uf I could repeatedly flash off a 4 or7 watt light blub on both caps and watch the amp meter as every thing refilled over and over the thing with the string the more caps the less energy you need to do this. Each new cap splits off some of the total charge and the charging plate needs less charge to fill it. I've used around 119 volts DC Thu my inverter and let the negative lead hang unconnected in mid air !. With more caps the charge gets smaller on each one but each one has the same charge on it the voltage is reduced witch can be a  good thing because that gets you to the point that you can use solid state but the total charge is still there but a lot less is needed to create it. The only ground is Thu the last cap.  If you just use two caps you get 50/50 on the system you pay for one you get one free ! But if you use more caps the energy is divided up  but the conductance and inductance remains and the ratio changes between them. Ben Franklin  demonstrated  this and referred to it as a economical way to charge Leyden jars.   Could you tell me how my light bulbs are firing off with out my negative connected ? O by the way with an small isolation transformer and a bridge rectifier you can do this on both the positive and negative lead using the same ground ! The transformer will be a door bell transformer used in reverse so I can get 400 volts to get close to by caps rating of 450. And a choke cap before it to reduce the power down to be safe . well there's most of it .PS don't be confused by the different voltages on the caps in the string the charge is all the same on each but the capacitance has changed due to the string series. Jim out. Please replicate .
" When you look at the formula for a set of caps in series each one is a reciprocal of the total every were you look on the net you get that answer and it's true as far as they go .what they didn't tell you was that the capacity is spread out being that the plates are spread out .the total is equal to the original single cap"
I have posted the idea of that exact theory just a few weeks ago.  This will be interesting. ;)
Mags
MagnaProp
Quote from: jimbo on May 06, 2016, 03:22:47 PM
I can if I can figure out how to post it...
Hi. Here are some images on how to post. I'm a visual person so I work best when there are images to see. The more you can post, the better. Thanks.
Pirate88179
Quote from: MagnaProp on May 06, 2016, 05:53:27 PM
Very nice tutorial on how to post images.  I am sure that will be helpful to a lot of the new folks here.
