real free energy with capacitors thru inductance
Started by jimbo, May 06, 2016, 12:10:35 PM
citfta
He is not shorting out the caps.  He is discharging them through the 110 volt bulb.  First one cap and then the other.  I am curious how fast you could do this if it was connected to some mosfets or fast switching relays and driven by a microprocessor or other timing device.  He is also using AC caps but since they are only being charged and discharged in one direction I wonder if regular electrolytic caps would also work.  Maybe Jimbo will comment on my thoughts.
Carroll
FatBird
I totally agree that he is discharging the Caps through a light bulb.  But since the Caps are DISCHARGED,
then how is there any Current or Voltage left to get over to the INVERTER and Charge the BATTERY?
See the problem there?
FatBird
PLUS, since he is charging the Caps through a Ground and a Wire in the air, why not Eliminate all of that
junk
and just charge a Cap DIRECTLY by placing it between a Good Ground Rod and a Wire in the Air?
Through a diode of course.
NRamaswami
Fatbird:
Please see Tesla's Apparatus for the Utilization of Radiant Energy. That device had an oscillator to discharge the capacitor continuously. Mr. Jimbo is using the swing switch ( what exactly is that? Like the old Bell switches but how does it work and where can we get one to replicate this?
Except the swing switch I can replicate the entire experiment as stated. I need to buy the choke cap. We can see if the batteries are charged or not.
I think he is alternately shorting or discharing the capacitors in series. When one capacitor discharges second in series charges and when the second in series discharges the first in series charges. The principle is correct but the schematic is a bit confusing to me.
Again the variance between Tesla Patent and this one is that the excess electrons are taken from the earth to the atmosphere here while in Tesla's Patent it is the opposite. It looks like the electron trap of Leal and Barbosa to some extent in principle alone of capturing electrons from Earth. But I might be wrong.
We need to experiment and see if this can be replicated. Experimental results always triumph. I have all the tools except the choke and swing switch. So no investment is needed at my end. really easy for me to replicate this. I can ask Jimbo for clarifications and do any possible improvements and share it here. Let us see if it works.
jimbo
The swing switch is just a wire with a clip on each end touching back and fourth between the cap terminals to fire them off . you don't need the clips just the wire will do this is bata on the  cheap testing don't. Use DVM for amp flow testing caps eat them for breakfast. A cheap analog from Walmart auto Dept works fine price around 11 bucks. The choke cap really was just there in my box may not need it. Don't get crazy with the voltage and exceed 400 volts .one bad thing about series DC is you can double the  rated voltage on the cap.due to plate spread but if you have a sudden short your now twice the cap rating  and big bang !! Like some c4 going off. Safety first cover the caps up with some thing . so your not picking stuff out of your face!.
That's 4 to 7watt bulb and just a standard 100volt neon. You probably don't need the bridge rectifier  just a good diode may work .I was just being true to what I had on the bench .things are adjustable .just get the DC 120 volts .I'm looking at going 400 volts and increasing the caps but that's another day. Jim out🍺
