real free energy with capacitors thru inductance
Started by jimbo, May 06, 2016, 12:10:35 PM
jimbo
Sorry I'm flying blind here everything I do is a hail marry pass . I looked at your new pic it's good but I used a cell phone (crappy pictures) and even worse drawing . and I can't read my bad hand writing with your new image. Is there a way to clarity it so my bad writings will come Thu ? Jim🍻
justwantfree
Jimbo,
This is somewhere along the same earth energy areas I've been experimenting with. From the "Barbosa and Leal" threads I've got several 8' grounding rods driven into the earth close to my shop. One rod is an input the others are output. Have solar bank of batteries,inverter, controller and cables to the rods. To my surprise and love for free earth energy, was and can harvest some free amperage to light a 14 watt cfl bulb. Of course thats anther topic.
Your idea has merit but I've not tried that way yet.
Have you tried a return from the ground other than the one attached to the meter? Be careful if living in a city area or close to relay stations. But if your residence is country and your area to test is away from utility poles then it's safe to try some different setups.
Justwantfree
MagnaProp
I tried to draw your diagram again. I'm not sure if I got the parts in green color correct.
It's as small as I could get it and still be able to read it.
FatBird
GREAT Circuit Redraw above.  Thanks.
FatBird
A Really Strange Thing is his Swing Switch.  Every time it swings back & forth it DISCHARGES
each capacitor through a Light Bulb.  That seems like it is DEFEATING the entire circuit and
DOESN'T leave any Voltage or Current for the Inverter to charge the battery.
Any ideas??
