yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
picowatt
MH,
I was referring to you revealing private comments made by the departed...
PW
Magluvin
Quote from: picowatt on June 20, 2016, 04:15:27 PM
Surely you mean to say this with regard to "ideal inductors", as in having no DC resistance...
PW
But even then, if the current is constant through the ideal inductor, what happened to the ideal voltage source? Did it also go to 0v, but is still allowing current? So did it change into an ideal current source at that point?
Mags
PW:
I don't disagree with that either, but I am fed up and that dose of harsh reality is to get him to back off.
picowatt
Quote from: Magluvin on June 20, 2016, 05:03:09 PM
Mags
I never mentioned an ideal voltage source...
PW
Magluvin
Quote from: picowatt on June 20, 2016, 05:12:30 PM
PW
I know you did not. But what voltage source is capable of 0v yet provides current to the ideal inductor? Sure we could just say that the inductor has no voltage across its leads but has steady current. But it seems in each case of whether it is current building up, or flat line current, if it is an ideal inductor we are talking about, then one question may come about as to the source. Current is rising in the inductor so there must be voltage across its leads? Steady current but no voltage across its leads? Id say the source needs more definition as to its capabilities in order for those to occur. Wouldnt you? ;)    Its like the ideal source is not just a voltage source whether it is adjustable or not, if it is capable of current at 0v. Then it is no longer a voltage source.. Its just some magical source that is simply capable of anything imaginable. May as well be a source of light also. Capable of coherent laser light output also. Provides mechanical and sound output also. Etc, etc.
Mags
Mags
