yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
tinman
Quote from: MileHigh on July 01, 2016, 01:12:48 AM
Brad:
So, you are never going to make a graph to back up your whackadoo "dual current" theory.  Surprise surprise.
For what it's worth, I count about 12 spelling, punctuation, and style mistakes in your posting #1570.
I actually responded to that issue in a moderate amount of detail but it passed right through you like you weren't even there.  Yes I could easily whip your ass on the bench, and that has been established beyond a shadow of a doubt, but it's likely that I will never go on a bench again.
I don't really know what you are talking about, and I am not really following the discussion.  Now, if you can actually formulate a proper question and not have it be the usual half-assed mangling of the English language and I can actually understand you without having to rely on a secret decoder ring, then I might try answering.
Odd how it is only you that ever has trouble  understanding what i  write-mmm?
So-you make the claim that you could whip my butt on the bench, but refuse to back it up.
I have seen your effort at building a simple electromagnet,and it looked like some one had a bad day with the reel on there fishing rod,so i think im safe there-on the bench.
Could you please post again-in detail as to how the current will flow without a potential difference between coil an source.
Thanks
Brad
tinman
Quote from: poynt99 on July 01, 2016, 12:24:07 AM
Then why do you say the 1p Ohm trace is wrong?
Or, if you're not saying that, are you saying that it is not close enough to ideal? If so, why?
Is the first 3 seconds of a 158 thousand year time constant not close enough to a perfect straight line for you?
As i said-at what point were actual real world measurements substituted  for math that just followed the trend of those actual measurement taken?.
If we look at what nature shows us,we can go from a liquid to a solid when we go from a value of 1 down to 0. So we know drastic changes are indeed possible in one small change-one value less,and we went from a liquid to a solid.
I am remaining undecided until such time that some one can give a solid reason as to how current can flow from a source to the coil,when that coil has the same voltage across it-->apparently
Brad.
Everybody has trouble understanding what you write, because sometimes the way you write is extremely odd.
Quotesome one had a bad day with the reel on there fishing rod
Grok this: They're going to get their rose petals and fishing rod over there.
tinman
Quote from: MileHigh on July 01, 2016, 06:41:59 AM
Or it could be just the fact that Australians do not always word things the same way as other countries-->did that ever cross your mind?
I mean,words can have different meanings.
E.G Complete and finished--seem the same-yea
If you have finished a project,it is now complete.
Or in your case MH,it ,makes you feel !complete! to argue with others here on this forum,but if you took me on in a build off,you would be !finished!  :D
Brad
No, it has absolutely nothing to do with the way Australians speak English and everything to do with your own personal problems with language.  Don't play straw man.  There is never going to be a build-off of anything, so fantasize away.
