yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
poynt99
Quote from: tinman on May 13, 2016, 10:36:26 PM
I have made the question very simple MH--see diagram below.
Brad
Is this loop current steady, or is it continuously-varying with time?
picowatt
Brad
When the supply is first connected or turned on (T=0) the voltage measured across the inductor will essentially be whatever the V supply voltage is.
It is still an inductor with reactance, and it will take time for the current flow to build.
PW
tinman
Quote from: picowatt on May 13, 2016, 10:45:21 PM
PW
You have not answered the question asked in the diagram below.
Brad
picowatt
Quote from: tinman on May 13, 2016, 10:48:24 PM
Brad
I believe I did answer the question.
However, if you are referring to DC conditions, the answer would be no.  But under time varying conditions, as in when you first connect the supply, the answer is yes.
As this relates to MH's original question, at T=0 there is a measurable voltage across the inductor.
PW
picowatt
Tinman,
I did not notice the short circuit you drew into your diagram.  I mistook those arrows for measurement points (only glanced, time is short right now).
Surely you do not believe that is the equivalent circuit for an ideal inductor with zero resistance.
PW
