yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
tinman
At T=0,the ideal voltage source is placed across the ideal inductor.
At T=3s,the current flowing through that inductor/ideal voltage source loop will be 2.4 amps.
From T=3s to T=5s(the 0 volt phase),the current flowing through that ideal loop will remain at 2.4 amps.
At T=5s,the ideal voltage source(being one that will supply 3 volts across a load,no matter what the load)wants to supply a voltage that will cause a current that apposes that which is already flowing through the ideal inductor/voltage source loop.
Being that both the inductor and voltage source is ideal,the energy stored in the ideal loop from T=3s to T=5s cannot be dissipated in order for a current to start flowing in the opposite direction,and the ideal voltage source says that it will supply 3 volts in opposition to the present current flow no matter what .
At T=5s,MHs circuit explodes.
Brad
wattsup
Quote from: tinman on May 14, 2016, 11:25:44 PM
Well, the circuit doesn't explode.  So think it through some more and try to come up with a better answer or perhaps someone else will chime in.
tinman
Quote from: MileHigh on May 15, 2016, 02:00:49 AM
Oh,of course MH.
The MH paradox kicks in,and the stored energy before T=5s,just disappears(it has to,as there is nothing in the circuit that can dissipate this energy),so as the ideal voltage source can now induce a reversed state of energy into the inductor loop.
This MH paradox is truly fantastic---it makes everything work just the way you want it to.
Throw out resistance,throw out time constant's,make DC mean what ever you want it to mean--who needs all that crap when you have the MH paradox-->you bloody ripper :D
Brad
Quote from: tinman on May 15, 2016, 02:29:19 AM
Oh,of course MH.
Brad
You have to think Plan B because Plan A is a no-go.
